I use teflon tape on those fittings.
Well,
I replaced the solenoid on my 210EXT (2014/15 model), because I either broke it (I forget) or just wanted a solenoid with NPT (24V online for about $20) pipe threads so I could have various angle fittings. I posted a thread here several years ago about it with pics.
Honestly, though, the fitting to the solenoid doesn't get much activity, as I'll just remove the line from the Argon tank at the regulator, for changing bottles.
So, teflon tape or thread sealant, take you pick, the fitting probably doesn't have a preference, especially if you leave the hose to it in place and just change the tank at the regulator.
And if you have a good seal at the regulator, even when you shut the tank valve your pressure gauge will hold a steady pressure for weeks, unless there is also a poor seal at the solenoid.
So, you always have that as a visual that all is well, when you see the tank pressure is staying "put" for weeks after the valve is shut.
Gee,
Now that I think about, maybe the seal at the entry of the solenoid doesn't affect the pressure held at the regulator after the valve is closed...
