Storm 215c
Hello,
I have a simple question on this unit. I am looking to buy this to have both a plasma cutter and mig unit all in one. My only worry is the note on it concerning plasma function.
Quoting from the notes section.
"The plasma function of this welder is meant to serve as a supportive function to normal welding operations. It is not meant to serve as a stand-alone, primary plasma cutter, nor is it designed for or capable of CNC use. The plasma cutter function is for hand cutting only."
I don't intend on using the plasma all the time but this has me wondering if this could potentially be a weak spot in the unit. I understand about not using for CNC but how limited is the supportive function? Handheld I am ok with and would probably use the plasma on and off but when I start on a project (A home user level) I want to make sure the tool I purchase will handle what I am going to do.
Thank you and God Bless,
DVD
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
