I have this unit, and when in stick mode after selecting the proper stick and weld material thickness the weld amps shown are not what the unit is welding with. in standard mode if the amps are showing lower, IE: 75 amps, this is what the welder is putting out. powerset mode shows 125 amps, standard mode shows 75 amps. until I raise the amps to 125 in standard mode and reselect powerset then the amp out shows appropriately. Does the powerset mode over ride the standard mode amp selection?
Thanks all for your input,
