Results 1 to 7 of 7
Thread: Power cool W300
  1. Default Power cool W300
    FYI, Just ordered (5/28/19) a PowerCool W300 220V from EL ; received a call from ordering department: back ordered till mid June. Appreciated the info. and phone call. I'm looking forward to the delivery. Great price!
    Nice!
    What TIG unit are you mating that to?
    Everlast 210 EXT (2015)
    Hi Christian, I'm going to use it on my PowerTig 185 DV, and my 210EXT. I retro-fitted a correct outlet on the back of the 185 so the PC w300 goes on with the welder. Really looks oem.
    Quote Originally Posted by stefdds View Post
    Hi Christian, I'm going to use it on my PowerTig 185 DV, and my 2018/19 210EXT. I retro-fitted a correct outlet on the back of the 185 so the PC w300 goes on with the welder. Really looks oem.
    Edit: 2018/19 210 EXT .
    I've been working with my new 210EXT, wow! Many options/ wave forms on AC ; not to mention pulse settings and a extensive frequency range. DC is also very adjustable, especially with DC Pulse and Frequency settings: 18 gauge SS is no problem now and it gets even easier to weld as you increase thickness of base materials.
    I also received a email: my PowerCool W300 has shipped from EL! I'm looking forward to utilizing its benefits (the wonders of water!) with my TIG welders and enjoying extended practice sessions.
    I hooked up my W300 and have some feedback for those of you thinking of getting into water cooling. I'm using the RV coolant mix (Amazon), it comes in a partially filled gallon jug with about 32oz's of coolant - you fill the partially filled container with distilled water ; that coolant mix now goes directly into the water cool. You will need two gallons of mix. All seems to be working well and I had no leaks. I plugged my w300 directly into the back of my 210 ext.
    https://www.amazon.com/Camco-RV-Anti...HWN45C7PJA4N1N
    For reference the dBs reading I observed were as follows: 210 EXT = 61 dBs. , the 210 With the w300 running is 72 dBs. and you can not hear the 210ext running. So, its a bit loud with the two running together. The 210EXT. is actually not bad at all ,noise wise, running by itself. We'll see, maybe a fan mod in the future. (see this old tony on YT for ideas).
    Haven't welded with it yet, I'll keep you posted. So far , so good! Also, if your just getting into water cooling, see my "heads up" post regarding water cooled tig torches (Nova).
    https://ehs.yale.edu/sites/default/f...evel-chart.pdf
    Yeah,
    My 210EXT, with it's always-on four fan implementation is so nice and quiet, I'll guess that it may be the quietest 200/210 amp AC/DC TIG unit that can be found on the North American market.
    It would be nice to see a sound comparison that includes a 210EXT, a SW200, a Dynasty 210DX, and an AHP Alpha TIG.
Tags for this Thread
