Results 1 to 20 of 38
Thread: Light and flexible torch for 255 EXT
  1. Default Light and flexible torch for 255 EXT
    hello everyone,
    i just joined in the forum and i just bought PowerTIG 255 EXT last dec. i haven't used it yet actually. i want to buy a couple of tig torches which are light and very flexible. the torches that came with the unit are bulky and rigid and heavy for me. though they have flex head, i still want similar to this
    http://weldfabulous.com/ck-ck1512hsf...ece-superflex/
    or this
    https://www.arc-zone.com/flexible-to...g-ck1512hsf-fx
    now, i have a few questions. i understand i need to buy male dinse connector that would fit the female DINSE 35-70mm² of my 255ext. and that dinse connector should have a gas outlet connector where i can connect the gas tube that will connect to gas outlet 9mm quick connect of the 255ext?
    i've attached some photos i screen captured from youtube (pithy bike's channel) to clearly show what i mean.
    1. what exactly are the correct flexible torches i can buy? for now i'm not going to weld anything more than 150amps i guess.
    2. where can i buy the dinse connector where i can connect the flexible torch and which has the gas outlet i can connect to 9mm quick connect of the 255ext.
    i have a lot of other questions but this is all for now.
    thanks in advanced for any help and guidance you can give to newbie like me.
    joe
    Yeah,
    If you want to piece-it-out with CK Worldwide stuff, the individual Safe Loc Dinse connector with the Quick Connect for most Everlast TIG units is CK SL2-35QD, priced at around $57, which would work great with a 17 torch and hose/power cable.
    https://www.amazon.com/CK-SL2-35QD-S...35qd+safe+lock
    But, more recently, Everlast now has their own Ultra Flex hose and torch assemblies with the Dinse connector built-in, so there's no added cost for it, but then it is never really detachable, which seems OK.
    I mean, while you're in the TIG torch assembly market, I'd consider the Everlast Rota-Flex TIG torch head/assembly too, which is similar to CK Worldwide's Flex-Loc but is more costly to obtain than the Everlast.
    So, it's a one-stop affair with Everlast for the Rota-Flex with their Ultra Flexie cable with the Dinse and the right quick connect gas fitting, without the gas connector being adapted from a compression fitting as CK Worldwide does it. And it's $149, out-the-door for the 12.5'.
    https://www.everlastgenerators.com/p...-35-type-dinse
    Everlast 210 EXT (2015)
    Yeah,
    Hey Christian do you have a Everlast Roto-Flex torch and if you do how do you like it? I upgraded to the Roto-Flex #9 torch which is supposed to be delivered tomorrow along with my 255. I'll have to reorder some tungsten UPS delivered an empty package today I noticed the envelope had a 4" tear so I must have tungsten scattered from N.J. all the way to Ohio.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
    Pakmaster 75XL plasma
    Nah,
    I don't have one because you can't buy one separately or cheaply, from Everlast, CK, or WeldTec.
    I mean, ideally I do want one, but my cheapo Flex 17 is adequate, and I've got a couple torch assemblies already.
    Quote Originally Posted by oleblu72 View Post
    Mark
    Ok thanks Christian. I have to learn how to run a tig before I start thinking about another torch or two anyway.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
    hi rambozo, christian,
    thanks a lot for a quick reply. i watched the youtube rambozo gave and clicked on all the links which christian gave. looks like i found the one mentioned in youtube is what i want to have. now, i'm still confused about these torches, the type, sizes, etc.
    i believe what was mentioned in video is: CK CK26-25-RSF FX TIG Torch Pkg 200A Flex, 25' 1pc SuperFlex
    (http://weldfabulous.com/ck-ck26-25-r...-fx-superflex/). this brings me to a question. is this type 26 torch? and if it is, this is big but it can do up to 200A as gas cooled torch?
    how about CK CK17-25-RSF FX TIG Torch Pkg 150A Flex, 25' 1pc SuperFlex ?
    (http://weldfabulous.com/ck-ck17-25-r...-fx-superflex/) is this a type 17 torch?
    CK CK9-25-RSF FX TIG Torch Pkg 125A Flex, 25' 1pc SuperFlex ?
    (http://weldfabulous.com/ck-ck9-25-rs...ece-superflex/) and this is type 9 torch?
    i'm clarifying this because i'm confused about the numbering system. and all the above mentioned torches gas cooled?
    my next question: are all these compatible with my everlast 255ext?? related question is can they fit the CK SL8-35QD SafeLoc Male Dinse 35 (1/2") (CK26,TL26) Q/D ?
    not that i'm buying all of them. i want to know first if all of them will work with my machine and then i will choose which one i want to buy.
    sorry, i have so many questions. can we not just buy the head alone (exluding the flex red tube) and then interchange them using one flex cable? is the red flex tube not detachable? or can we just buy the head alone at all?
    it's very costly if i want to have at least 2 of them with individual flexible cables. i'm also weighing my option and future applications if i want to go with ck17 and ck26. but i'd be happy to have all the 3 if i can buy only the 3 heads and 1 flex cable and would be able to change the head that i need or prefer to use at any given application.
    i hope i'm not confusing everyone as much as i am confused with the torches
    ok, last questions for now. the argon gas inlet at the back. it's annoying that it's in the middle. is there any L adaptor type we can use so the gas cable won't be nodging the gas tank? is there anyway that can be converted to a quick connect? and the clear gas hose, any recommendation for a replacement for it? looks flimsy to me.
    btw, amazon US can not ship any of this to australia (not sure why). there's already amazon.com.au but they don't have this item as amazon is new to australia. so i'm going by weldfabulous or other dealers who have this and will ship to australia. any idea which offers these items the lowest price?
    thanks again.
    jo
    The US 255ext torches in the new units aren't bulky. They are very similar to CK standard line torches and flex cables, and if anything will carry a bit more power. I think it's probably prejudice. Once you put them side by side you won't be able to tell the difference in bulk.
    The NOVA rotaflex are available direct and individually from Everlast. Just call. Also these torches are nearly identical in construction to the CK and cables are just as flexible, and the dinse connector is better in my opinion. Way cheaper, and they have a two year warranty IIRC.
    hi mark, i got my 255ext here in australia (everlast-welders.com.au). are you saying the unit in australia and the units in US come with different torches? because the torches that came with my 255ext are bulky. they are no different from my cigweld torch. bulky with unwielding cables.
    thanks
    I would imagine so. We use the 9 and 20 torches here on the unit.
    Just a quick note, there are 2 lines of CK torches, I'm not clear on the actual differences, but there's a standard series and a master series. They are very close in price. The master series has an H in the product number, where the standard series has an R in the number. You list the R models above. If anyone knows the actual difference, can you let me know?
    Alan
    CK literature indicates that the main difference is that the "Master" series has a stainless threaded insert at the head, which is where a collet body screws into. Potato-potatoe, tomato-tomatoe.
    Basic torch numbering is/was standardized across different brands, but there are some exceptions.
    The big differences are the different hardware that each torch uses. There are two major versions of hardware and a few specialty versions. They use different size threads so they do not interchange.
    The small hardware is shared on the 9 series gas cooled torch and the 20 series water cooled torch.
    The large hardware is used on the 17 and 26 gas cooled, and the 18 water cooled.
    There is also a special stubby version that basically uses the small hardware size on the large series torches.
    The cables use standard connectors, but will be different sizes rated for different current. Same with the torches and hardware, they will all have a current limit and you should not exceed the maximum rating of any of the parts. For example the stubby hardware will lower the rating of your torch somewhat. So while you could put a 26 torch on in place of a 17, the cable that came with the 17 will not handle the current that the 26 torch can use. So while you can mix and match, you have to be aware of what the weak link is and not exceed the lowest rating of your combination. In practice the brand make more difference in torch sizes. CK has 17 and 26 torches that are practically the same size. But the cables are different to accommodate the different current limits of each torch. So if you wanted to use only one cable, make it a 26 and you could swap a 9 or 17 torch with no worries about overloading the cable. It would just not be as flexible as it could be for a small 9 torch. It all depends on what your priorities are. My advise is to use what comes with the machine for a while. See what type of work you do and you will have a better idea of what you need in terms of size, current, and cable length.
    Yeah,
    The one CK Worldwide Safe Loc Dinse clamshell will not fit both 17 and 26 hose/cables, or their water-cooled equivalents. So CK has got you for over a $100 just for two connectors on a 17 and a 26 torch, if you have both, as I do. Everlast torch assemblies don't have that separation or added cost, even though the separation can have some advantages.
    The SL8 will work for a 26 TIG torch and hose. The SL2 will work for a 9/17 TIG torch and hose. The 35 suffix designates the 1/2" Dinse (a 25 denotes 3/8"), which is what Everlast has on the 255EXT, and the QD designates the 9mm quick-disconnect which the Everlast also uses.
    I don't notice a CK SL8 Safe Loc model that denotes the "QD", so I'd buy a barbed 9mm quick-disconnect fitting and some Oetiker clamps, which are a more elegant solution than how CK uses a compression fitting with a QD 9mm adapter on their SL2-35QD for the 9/17 torches. Everlast sells the 9mm fittings. I mean, that's what I did, even on a SL2-35QD I have, since I wanted to shorten the small gas line to the Safe Loc anyway.
    There is an adapter to reduce the 7/8 to 5/8 but it probably would not fit in the plastic clam shell that CK uses. It is a WeldCraft item. Also water cooled while being the same 7/8-14 thread, is left handed to avoid mixing water and gas cooled items. Same with torches that use CGA B 5/8-18 lines for water and argon, the argon is right hand thread while the water is left hand. One downside of Everlast using the same QD fittings for both water and argon is a number of people end up pumping water out the front of their torch and come here complaining about defective torches. So if you want to upgrade to water cooled, you will end up buying yet another Safe-Loc end.
    Yeah,
    It'd be nice if CK Worldwide would just include an adapter like that so people could use their "patented" Safe Loc on 17 or 26 torches right out of the box.
    I mean, it might cause a few less sales, but I'd have more respect for CK that way, as I currently look for any alternative to patronizing CK Worldwide, since their pricing is high and they seem to have almost no competition, until just lately, with Everlast flexie hoses and Rota head stuff.
    There are now imported wedge collets now, too, as an alternative to the CK stuff, which causes one to buy 5 wedge collets of the same size at a time, but the import stuff often includes four different sizes, which is a money saver and reduces order making. I just don't know if the imported stuff has wedge collets for the stubby gas lens kits yet, i.e., not the standard 9 or 17 collet types/lengths.
    https://www.amazon.com/s/ref=nb_sb_n...=wedge+collets
    thanks a lot for that rambozo. very clear and helpful specially for a newbie like me.
    also, i found this in the CK website. one just needs to look around. but also it's better to ask as well when you really can't find what you're looking for.
    http://www.ckworldwide.com/dinse-gas-cooled.html
    this tells which torch goes with which dinse. i want to order a couple and i don't want to make a mistake because shipping from US to australia takes time and costly as well.
    Thanks Christian for pointing out the differences between the standard and master series. What Rambozo explained makes perfect sense as I have the stubby kit for the 26 torch and it basically allows the cups used on the 9/20 to be used on the 17/26 torches.
    I know this is diyjer's thread, so just commenting for myself here, but this is what I plan to do. I ordered a flex head for my 26 torch. This will get me what I need in a 200 amp torch and what I will use for a month or two, possibly longer, until I get a CK 17. I want the smaller 150 amp hose for the flexibility, but the red flexible 200 amp hose on the newer Everlast is not too bad, IMO. It is very usable and why I plan to use it for the time being. That way I'll have a 200 amp setup that I can change between rigid or flex and a 150 amp flex. Another option would be the 17 rotoflex, could be the best of both worlds on the 150 amp 17 torch. For the time being it doesn't matter as I will be using the torch that came with my welder.
    Alan
  19. Default
    Yeah,
    That's a similar attitude to my own; I use the 17, but like having the heavier 26 as a back-up.
  20. Default
    Quote Originally Posted by aland View Post
    I know this is diyjer's thread, so just commenting for myself here, ....
    Alan
    hi alan, this is everyone's thread. the more (info) the merrier. i'm liking this community already
  1. Supercut 50 p warning light
    By Memnos in forum Everlast Plasma Cutters (PAC)
    Last Post: 03-14-2013, 10:06 PM
  2. Flexible snake arm clamps for Tube welding?
    By Welderooni in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 12-27-2012, 08:41 PM
  3. Where can I find a flexible tig torch hose?
    By brianscott in forum General Welder Questions
    Last Post: 11-10-2011, 02:35 PM
  4. Protection light on PT225LX
    Last Post: 04-08-2011, 02:39 AM
  5. Supercut 50 over current light
    By outsidegangskilled in forum Everlast Plasma Cutters (PAC)
    Last Post: 09-11-2010, 01:25 AM
