Results 1 to 3 of 3
Thread: Concrete Plug and Fence Post Pulling Lever
    Aug 2014
    Westerville, Ohio
    Default Concrete Plug and Fence Post Pulling Lever
    Scrap yard acquired eight foot I-beam, short piece of angle iron, and some beefy rebar, fashioned into a lever to pull fence posts.
    There are three chain stays welded to the top of the beam. On the jacking end another section of rebar acts as a jack stop.
    It's nice when the scrap comes sized perfectly for the application. I only had to cut the rebar pieces to length.
    The wooden cribbing was already on hand from the house jacking effort.
    Not complicated but certainly effective for removing some massive concrete fence post plugs.
    Photo #1. Full length of lever.
    Photo #2. Bottom of jack end with rebar jack stop.
    Photo #3. Lever foot/fulcrum end.
    Photo #4. Top of lever with three rebar chain stays.
    Photo #5. Lever set up and in-use.
    Photo #6. The most massive plug of the bunch pulled. I would guess around 300 lbs.
    Photo #7. Results of a long and physical day of effort.
ID:	13593Click image for larger version.
ID:	13594Click image for larger version.
ID:	13595Click image for larger version.
ID:	13596Click image for larger version.
ID:	13597Click image for larger version.
ID:	13598Click image for larger version.
    There's an easier way my friend... posts will come up with ease.
Name:	Southern style.jpg
    Aug 2014
    Westerville, Ohio
    There are a myriad of ways to slay this dragon. The truck method may work on a ranch with plenty of level real estate, but on the sloped front lawn of a typical suburb?
    Just illustrating one of may ways to accomplish the task. Employ the one best suited to your particular situation.
  1. Robust garage floor concrete patch with welded rebar.
    Last Post: 10-13-2016, 01:59 AM
  2. wrought iron fence repair: wire and settings needed.
    By johnnymg in forum General Welding Questions
    Last Post: 08-22-2013, 05:37 PM
  3. Concrete planter
    By CGCINC in forum Personal Projects (no welder required)
    Last Post: 05-30-2013, 02:07 PM
  4. Replies: 0
    Last Post: 11-29-2012, 03:09 AM
  5. On the fence
    By jdt1986 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-24-2011, 11:00 PM
