Thread: Dinse reducer?
    Mar 2016
    Okinawa, Japan
    Default Dinse reducer?
    Maybe I'm not looking in the right places but I have a EXT 210 and have I think it's a 24 series torch from CK. Problem is the torch is 25 Dinse and the machine is 35 Dinse. Where can I get an adapter?
    CK will be your best bet. They Have a bunch of different options. Youll probably have to buy a whole new dinse connector with the right gas option. If you call them, they are very helpful.
    Quote Originally Posted by pavetim View Post
    http://store.cyberweld.com/twdiad50x25w.html
    Many other options as well.
    Edit: Missed that you are going the other direction. Don't see as easy a fix for that. You might have to replace your DINSE plug. There is this, but probably better to just replace your plug.
    http://www.longevity-inc.com/company...-dinse-adapter
    Oct 2013
    Glendale Arizona
    Default Reducer
    eBay chnsales European quickly inserted panel conversion head 35-70 to 10-25 $7.99 Item number:
    181682387684
    There's an Aussie eBay seller (bobthewelder46) that seems to have an elegant solution, which may be a good source for you on Okinawa, even though a little pricey.
    Everlast 210 EXT (2015)
    Quote Originally Posted by azsprint6 View Post
    181682387684
    Perfect! I knew there had to be something like that, but damned if I could find it.
  1. How many Dinse connectors are there???
    By Brian Ski in forum General Welder Questions
    Last Post: 08-25-2014, 04:53 PM
  2. Dinse connectors??
    By fernesto in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 05-02-2013, 05:59 AM
  3. dinse adapter for 210ext
    By miker2 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-06-2012, 03:39 AM
  4. dinse connectors
    By bobwills in forum General Welder Questions
    Last Post: 12-28-2011, 03:24 PM
