Results 1 to 20 of 25
Thread: Got a spark, but no cut, not an Everlast unit though.
    May 2010
    West Seattle
    Default Got a spark, but no cut, not an Everlast unit though.
    This is for a CT520D 3 in 1, not a Everlast product. We're getting a pilot spark, but the plasma will not kick in. Can you guys give me a list of what to check out to find out what the problem is?
    Cliff
    A warped mind is a wonderful thing to abuse
    Hi can you let us know what make it is . It is possible you have to adjust your gap as even though you have some spark it may need to be gapped to get optimum spark. Depending on the make this could be a screw adjustment or simply bending the leg.
    Cheers
    EVERLAST CANADA
    www.everlastwelders.ca
    www.titanwinches.com
    905 637 1637
    May 2010
    West Seattle
    It's a Simardre tech.
    Hi CSR
    That is a bit Tricky. the problem is that if Simadre and some others are still getting there units from the Supplier i visited a couple of years ago there is no way of telling what configuration the HF board is.
    The problem is they do not produce the PCB boards themselves and in fact from what i saw there where at least 2 different layouts being used.
    They would not admit this to me of course but having visited there ( i hesitate to call it a Factory ) Old Colonial Mansion from the days of Imperial European Involvement in China there was no facility for making boards and in fact absolutely no indication of this being done there. In a way this may be a good thing given the poor state of the building for this type of intricate work
    The Board in question is a small 3"x 3" board on the bottom base front of the machine and if you contact Simarde they should be able to supply this to you.As i remember it is not very difficult to replace as it is only 3-4 plugs to switch over to the new Board.
    I have a feeling the boards are put together as a cottage industry and i can just imagine a family sitting in a small room surounded by chips patiently soldering each tiny component.
    Cheers
    Duncan
    EVERLAST CANADA
    905 637 1637
    May 2010
    West Seattle
    Duncan.
    Would it help if I took a picture of the board, now that I know what to look for to see if it can be adjusted?
    Cliff
    Yes it definately would help . The HF points themselves could be one of three different types . I think the most common that i seem to recall seeing was a brown plastic ( U -shape holder) but i have no way of knowing your configuration without seeing it .
    Cheers.
    EVERLAST CANADA
    905 637 1637
    May 2010
    West Seattle
    I've got a picture of the board. Or I'll say I hope it's the right board. It's in the place you said and there's a small brown horseshoe thing you mentioned. If I need to take another shot just let me know, of what and from what angle.
    Check the gap between the 2 points that are mounted in the horseshoe . I seem to recall a credit card is a good spacer and it is non metalic. And i would also suggest you check all connections to make sure they are firmly seated. If this does not solve your dilema i Would suggest contacting Simardre and requesting either a new board or depending on Warranty purchasing the Board.
    either way keep us posted and hopefully it is a simple case of resetiing the gap .
    Cheers
    EVERLAST CANADA
    905 637 1637
    May 2010
    West Seattle
    Well I just did my 1st attempt at adjusting the gap. The space was tighter then a credit card. So I backed it out a bit and gapped to the card. Everything looks tight, no blown resistors or anything. No go, same thing. I'm going to try it a little closure after the caps cool down. Waiting to hear from Simadre.
    Cliff
    May 2010
    West Seattle
    Sorry for the extra long delay, but life got in the way. I've tried to adjust the gap a few different times now. No luck, the same with any response for Simadre's so called tech support. I got 1 back from him then no responce to the next 6 emails. So how do I figure out what board I have and who is the best company to get a replacement from?
    I'm going through a move right now, but should be settle in a month or so. I need the plasma at the new location since I'm losing the use of a water jet.
    Cliff
    If that is from Chiry (sp) there should be others that can help you on the internet. Also, there is a yahoo group for Chinese welders and they seem to all be that company (think there are schematic for the HF board too). Our units are different with IGBT, etc. See if you can find a name on one of the other PCBs (boards) in the machine.
    If you email support@everlastwelders.com I can send you the exact link to that forum. I know most of our "competition" are selling those units, so someone should be able to get you a board.
    Or maybe you can get Oleg in sales to upgrade your unit as an option when you get settled in. I do not know what the loss of a water jet is, but I can bet that hurts. Would love to have one myself.
    May 2010
    West Seattle
    I'll check out those other options. IF I can't get my plasma back, I'll be looking at 1 of the EL plasma's
    You know what a CNC plasma is, then think of no clean up, perfectly cut edges, thinner cuts and you have a water jet. A friend owns a granite fab shop and he has a large water jet for doing the counter tops. Another friend had a 4x8 plasma table and the water jet will cut finer details then the plasma could. All I need to do is a drawing in Corel or AutoCad and run over to the shop after hours.
    Quote Originally Posted by CSR View Post
    I friend of mine has a large pasma CNC at an ironworks factory. My guess it is 12'x18-20' It is big. I've seen $500 DIY waterjet claims on the internet. That would be a great investment if they work. Wish someone had a kit system for the price.
    May 2010
    West Seattle
    I used the CNC plasma for a long time before for my friend Plamer said he's bet his water jet could do a better job. That was cutting out small plates for armor. The plasma would pierce the holes and I'd have to re-drill them (8 holes per plate) any thing smaller then a 1/2" hole was a pain for the plasma. The water jet cut out everything. I was not thrilled will drilling out over a 1,000 plates, but it was better then cutting and drill out that many. LOL...
    The biggest problem with home made CNC's is the software. Building 1 isn't that hard. The difference in the cost of a good motor over a cheap motor is minimal. I've seen schematics for XYZ controllers on the web, but then again the controllers are that bad of a price. Then getting your hands on a pump that can cut at least 1/2" with a tank of water to cancel the cut would be fun to build.
    I've been looking at the high end 50 plasma ( the eBay prices are weird, the mosets are like 400, you/Canada has the power for 550 plus shipping and the US has then for 750. I've seen the 3 in 1s with the IGBTs for 800. Got to wonder why the 3 in 1 is so cheap come paired to the plasma.) But I haven't seen a vertical cutter head for a CNC. Lots of things to consider before I make my final plans.
    CSR,
    The 1 in 1 (plasma) and the 3 in 1 (DC TIG/plasma), both take a power supply, inverter, case, HF board, etc, etc. You just add a couple switches and boards to add a TIG/MMA to a plasma machine (and bigger case).
    You save on the 3 in 1 by not having duplicated of a lot of things in seperate units. That said, you also have more weight, heat (can be less duty cycle), etc.
    I like having mine separate, I have the room, that helps. No swapping around torches and gas/air when I realize I forgot to cut some pieces, after I already started welding things up. Guess I am getting lazy. Also, an Everlast employee discount helps. Though our prices are fair, Oleg will hook most people up if you call into sales.
    If you find a good water jet DIY, keep me in mind.
    The Vertical Machine head Torch for the Power Plasma 50 is not yet available. However i have discussed this with the Engineers . My last visit was part of this discussion and it seems they will need to develop a Set of consumables rated to the 50 for use in the machine torch they currently have to get the best performance for a basic CNC application.
    To be honest the TIG torches ended up taking priority over the Machine head and i have not pursued this with them lately.
    Now that the verdict is in on the Quality / Performance of the Accesories i can and will spend some time following up on this option and the viability of having it.
    Cheers
    EVERLAST CANADA
    905 637 1637
    The Trafimet S 75 machine torch can be fitted to the unit with little or no problem especially since we are using the new connectors that will interchange. This torch is more inline with the duty cycle that is required to maintain the cutting time that a CNC is capable of.
    May 2010
    West Seattle
    There's a number of factors that make a DIY water tough. The biggest is a proper head, you can buy a head, but then comes finding a pump that will deliverer the right psi. Then finding the right fittings and hose for the system is pricey. But with that much pressure going through the line, I wouldn't want to scrimp on parts. Which is the main factor against DIY water jets. The price, you can buy 1 of the best plasmas for less then you can build a water jet.
    Most of the guys here can build a frame to handle either a plasma or water jet. The jet should be a bit stronger. But for the jet, you'd add a water tank under the cutting surface (2" minimum deep), a large pump and reserve water tank, a pressurized abrasive hopper tank, a filtration system to prevent abrasives form getting to the pump and other parts, Then the last fun part is trying to get a way to reclaim as much of the abrasives as you can from the main tank.
    That my friends is the short list of the problems.
    May 2010
    West Seattle
    For right now, I'm leaning towards the Power 50. Having a vertical head would be great but not really important. Since most of what I do is 1 offs, a CNC is over kill (Like most of us here haven't been accused of that). I think the 70 or 80 would be a better choose for a CNC and to be honest, I'd want a water table. Just because is that much cleaner to work around. But then a under water plasma torch isn't cheap. We all should be thankful dreaming is free.
    Well, it has not been a priority here. But I have seen them work and it is quite impressive. The power and pressures.
    Maybe I will plan on a CNC and get me a PP50 and go from there, when I get time of course (I might never have a CNC machine if time is required though unless I buy one ready to go).
  1. AC TIG Arc Shots Demo First-Of-Kind Everlast 221 STi AC/DC TIG-MIG-Sick Multi Unit
    By christian in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 04-02-2018, 04:28 PM
  2. What You've Welded Recently With Your Everlast Unit
    Last Post: 02-26-2018, 02:39 AM
  3. Mr. TIG with a CK Steady Grip TIG Amptrol for Everlast EXT Unit
    By christian in forum General Welder Questions
    Last Post: 10-12-2015, 04:25 AM
  4. Setting the HF spark gap EVERLAST Cut40-60D
    By everlast_support in forum Everlast Plasma Cutters (PAC)
    Last Post: 02-05-2009, 08:57 PM
