Results 1 to 3 of 3
Thread: New 140ST owner has question about electrode initial sticking
  1. Default New 140ST owner has question about electrode initial sticking
    Hello, new to the forum and a new owner of 140ST machine. I am just wanting to stick weld. I have some limited stick experience. My question is, after playing around with the machine, the electrode is sticking on a cold piece of steel using a new electrode. After several tries, the arc starts and the machine welds great. Very smooth. Arc can be restarted fine after the initial sticking. I am using 6013 3/32 electrodes running about 60A on both 220 and 110v. Just wondering what you think might be causing the initial sticking? I am amazed at how small this machine is. My only experience is from the older style transformer-type machines. Thanks for any advice!
    That's why they call it "stick" welding.
    It just takes practice to strike a clean arc. Even more practice to strike it exactly where you want to. 6013 isn't too bad for clean starts. Use a motion like striking a match, where you are moving the stick before it touches the metal, then pull away just a bit as the arc starts. Different rods start differently and especially restarts. You might want to bump up your amperage a little depending on the material you are welding. Also make sure the 140ST is set in the stick mode, so the auto hot start feature will work.
    Thanks, Rambozo. I started with the match method and it starts much better. I also checked the TIG/Stick switch and I did have it on "Stick". In the past I have started rods by the "Tap" method. I am still using that once the rod is no longer new. It lets me start the arc exactly where I want. I also have a new auto-darkening helmet. It is great. I wish I had had it when I learned to weld many years ago.
  1. PowerArc 140st input amps question
    By MotoJ in forum Stick Welding (SMAW)
    Last Post: 10-02-2012, 04:34 PM
  2. 250ex initial months
    By notawelder in forum Customer Testimonials
    Last Post: 03-25-2011, 07:53 AM
  3. Initial thoughts of my 250ex
    By PinkNinja in forum Customer Testimonials
    Last Post: 03-18-2011, 02:35 AM
  4. 256 Initial review
    By Tony_F in forum Customer Testimonials
    Last Post: 03-11-2011, 09:45 PM
  5. Superultra 205 initial review
    By agrrob in forum Customer Testimonials
    Last Post: 06-27-2010, 12:01 AM
