Results 1 to 5 of 5
Thread: Robust garage floor concrete patch with welded rebar.
    Aug 2014
    Westerville, Ohio
    Default Robust garage floor concrete patch with welded rebar.
    The garage slab is to the right, top, and left of the photo. Six inch deep half inch diameter holes were drilled into the garage slab. Rebar was then pounded into the holes. Additional rebar was then welded to the pieces sticking out of the holes tying the individual spans together.
    No rebar ties the driveway slab and the garage slabs together. They suffer different temperature, weather, and load characteristics. The expansion joint between the two will remain just that, an expansion joint.
    Pure utility, nothing glamours or creative. It is, however, exceedingly stout concrete repair.
    Looks like it will do the job. Sometime simple it all you need.
    Aug 2014
    Westerville, Ohio
    Photo of finished and cured concrete patch. The gloves are for scale. Sorry about the shadows, the low angle of the sun through the trees makes for the distracting contrasts.
    Aug 2014
    Westerville, Ohio
    Geico gecko gloves?
  1. Concrete Plug and Fence Post Pulling Lever
    Last Post: 04-29-2017, 10:11 PM
  2. Tigging a radio patch panel?
    By Dne007 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-07-2014, 12:20 AM
  3. Pressure washer trailer patch
    Last Post: 11-28-2013, 02:27 PM
  4. Concrete planter
    By CGCINC in forum Personal Projects (no welder required)
    Last Post: 05-30-2013, 02:07 PM
  5. project 4 from ogorir: inner quarter panel patch
    By ogorir in forum On Road Fabrication
    Last Post: 10-25-2011, 04:23 AM
