Results 1 to 3 of 3
Thread: 970 Crawler Rear Diff
    Default 970 Crawler Rear Diff
    Hybrid 9 inch Ford with Dana 70 spindles and 35 spline axle shafts. Have build pics if you are interested
    Everlast PowerTig 200DV
    Miller XMT-300
    Miller S74 MPA Plus
    Thermal Dynamics Plasma
    Bridgeport Mill w DRO and VFD
    Clausing 6913 Lathe
    JD2 Model 4 Bender (air over hydraulic)
    HF Tube Roller (powered)
    HF Bead Blasting Cabinet
    Rigid 15" Drill Press
    https://www.facebook.com/pages/G-Fab...=photos_stream
    Nice!
    Is it that u-joint shroud and the brake brackets that you did on it? Are they aluminum or powder coated steel?
    The Pinion Guard and Brake brackets are both from Ruff Stuff Specialties and are painted hi temp silver.
  1. Sidewinder Rock Crawler
    By cbmkr in forum Off Road Fabrication
    Last Post: 01-22-2013, 06:31 AM
  2. 1996 Toyota Tacoma made into an off-road racer/mall crawler
    By Tacoma747 in forum Truck, Car and Bike builds
    Last Post: 06-06-2012, 02:25 AM
  3. Project #8 From Jason: Transmission Limited Slip Diff Install
    Last Post: 06-15-2011, 12:00 PM
  4. Ford Bronco rock crawler
    By ScratchStart in forum Off Road Fabrication
    Last Post: 04-29-2011, 08:05 PM
  5. Rear Bumper
    By Krookz in forum Off Road Fabrication
    Last Post: 03-18-2011, 10:44 PM
