Results 1 to 13 of 13
Thread: 4bt Cummins motor mounts
    Default 4bt Cummins motor mounts
    Started motor mounts for my jeep tj Cummins projectClick image for larger version.
ID:	13084Click image for larger version.
ID:	13085Click image for larger version.
ID:	13086Click image for larger version.
    Sent from my SM-G900V using Tapatalk
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Looks good, what did you make the bends with ?
    I bent them in my press brake from swag offroad
    LONGEVITY 250EX Tig
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    LONGEVITY 250EX Tig
    Looks much better. I was kinda worried about the flat ones you showed before. Looked like a recipe for harmonic vibrations and then cracking. Hard to tell from the pics, but I would make those standoff spacers, on the right side, at least as large in diameter as the cast bosses they sit on, and weld them to the plates, so the bolts don't see any bending moment and are loaded in shear and tension only. Very cool project.
    LONGEVITY 250EX Tig
    Nice work.
    Nice work.
    LONGEVITY 250EX Tig
    LONGEVITY 250EX Tig
    LONGEVITY 250EX Tig
    That table cuts very nice. I never did get me a CNC Working on a 3D printer next.
    LONGEVITY 250EX Tig
    Something rather odd to do with a Cummins powered Jeep.
  1. Cummins turbo mount
    Last Post: 10-28-2017, 07:03 PM
  2. Cummins exhaust manifold cut to fit
    Last Post: 11-19-2014, 08:56 PM
  3. 1936 Ford Schoolbus with Cummins 5.9 NV4500
    By Tacoma747 in forum On Road Fabrication
    Last Post: 08-20-2013, 08:27 PM
  4. Aero bar mounts
    By Rambozo in forum Personal Projects (no welder required)
    Last Post: 07-10-2012, 02:28 AM
  5. Shackle mounts
    By roadymi in forum Off Road Fabrication
    Last Post: 09-24-2009, 12:48 AM
