Results 21 to 40 of 44
Thread: Help with spoolgun aluminum welds
    gun positive, same as steel hard wire. If you reversed it some time to run flux core and did not change it back you that might be your problem. I also presume you are running straight argon gas.
    Straight argon... all info in the picture and description. My flux core days are over, I've had enough of that stuff to do me for the rest of my life.
    I went back to your first post and read you were using argon. I did read it but that was a few days ago and I forgot what was in it. How did the .045 wire work?
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    I wish my flux core days were over too. But I do a fair amount of welding outside and in most cases the flux core is faster than stick welding everything.
    millermatic 200 mig
    2016 Everlast 250EX
    miller tig cooler
    Maybe Jody heard your complaints...
    https://www.youtube.com/watch?v=hUpmiDL92V8
    Neat scotchbrite trick.
    Thanks, I'll try his tips. He makes the best welding videos out there and he's the reason I bought my first Everlast machine.
    "Other factors also can be responsible for inadequate shielding, such as contaminated shielding gas or hydrocarbon contaminants on the surface of the filler wire or parent material.
    But if the smut is just aluminum and magnesium oxide, why is it black?
    These substances are white. The particle size of the oxides in weld smut is so small that it acts as a light trap and appears black."
    When you're using 5k series wire, you will never get rid of all smut.
    With all do respect to the guy in the video, if I tried the ScotchBrite tick in the gun barrel, I'd have a nice plastic molten goo to deal with!
    The wire curling is common with small wire and can be obviated somewhat by using the tightest tip you can as long as it doesn't create other problems. 5356 is much stiffer than 4043 and if there is a choice, make sure your liner is the right diameter. I can say honestly that I've never had a bad roll of wire. Recently I ran some Chinese stuff that was as good as any.
    What thegary said about wire speed is true and his advice to stick with 3/64 is sound.
    You must post more close-up pics.
    Well are you welding with 5356 yet?
    millermatic 200 mig
    2016 Everlast 250EX
    miller tig cooler
  8. #28
    I tig welded my boat stringers with 5356. My spool gun has to be sucking air somewhere because I've been through every setting systematically several times with the same results. It can't be the gas since I use the same bottle for tig.
    I haven't been out to the shop for a while since my best friend and fishing partner got out of the fence and was run over and killed by some a-hole who didn't bother to stop.
    Sorry to hear about your best friend and fishing partner.
    My condolences, as well.
  11. #31
    That sucks Zoama. Sorry to hear that.
    Gerald
    Millermatic 251
    Spectrum 300 Plasma
    Everlast PowerTig 250EX
    Everlast PowerCool W300
    Harris / Victor OA
    ProTools Air/Hydraulic Bender
  12. #32
    Yea, that does suck. I lost mine a couple years ago. Due to my age opted for no more. But you are probably young and will get a new fishing partner your old one will approve of. Sorry to hear about it and down here they would not stop either.
  13. #33
    I'm 50, she was 2. It's illegal to hit a dog and not stop here in South Carolina. I only wish they had stopped to give me a chance to save her.
  14. #34
    I have you by 7 (I figured a lot more). I know it sucks though. Crazy here, you hit a duck and there is a fine. Not sure if anything for a dog.
    I know when mine was hit it there was no hope though. Private road and all but it still happened. I wish you well. Hang in there. 1 year, 2 year 10 years. All hurts.
  15. #35
    I have being reading this post on spool gun and aluminum welding on mine it was the gas flow was to low on tig welding at was set to 25 to 30 SCFH @ 50 PSIG for aluminum and had to go to 50 to 55 SCFH @ 50 PSIG for the spool gun to get it to work with 5356 but 4043 does work a lot nicer. Sorry about you fishing buddy, had my buddy for 17 years still miss the old girl after two years had a heart attack, dog have them too.
  16. #36
    I hate to throw money at problems but I could not make the other spool gun function correctly. It sucked air and had erratic wire feed speed. I tried and tried but couldn't correct those problems.
    I purchased the same basic spool gun from Mundaka but it has a much nicer one piece lead, same as a regular mig gun and uses common Tweco front end parts. I changed them to the screw on 23 style that I use on my Profax mig gun.
    My skill isn't there yet and I'm guessing at pulse settings but I at least have a starting point now. I also learned from an old Esab chart that 5356 needs lower voltage and higher wire speed than 4043.
    Here are a couple of pics I took about two months ago when I got the new spool gun and started testing again Click image for larger version.
ID:	13603 Click image for larger version.
ID:	13601 Click image for larger version.
    I've been working a lot more lately so I haven't had much testing time but I think I'll catch on quicker now that the spool gun problem is solved.
    If anyone would like to share pulse settings for .090 aluminum I'd love to test them. I might even learn to weld in a straight line.
  17. #37
    I will get the starting range my son uses. We do 4043 all the time and look great. No spatter. We have never got it to spray with aluminum either.
  18. #38
    Any luck finding those settings? Do you use different settings for 5356?
    The forum has that jumping cursor problem again where midway through typing a sentence the cursor jumps to the line above.
  19. #39
    With 4043 .047 it work very well on my MTS 250 V23.2 wire speed and amps 276 100% argon set at 22CFM no smoke nice clean weld on a aluminum .25 and .375.
  20. #40
    Thank you for the tips but 99% of my spool gun work is .090 aluminum sheet and tube. I need pulse to prevent heat buildup from burning through.
  1. First aluminum welds- nothing to write home about
    By DaveO in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-28-2013, 12:14 PM
  2. Frosty looking welds with Aluminum? Everlast PowerTig 225LX
    By Welderooni in forum General Welding Questions
    Last Post: 10-13-2011, 08:14 PM
  3. Post your best aluminum welds!
    By TonyR85 in forum Other Custom Fabrications
    Last Post: 03-30-2011, 04:48 AM
  4. First aluminum welds with PT200DX
    By sixturbosix in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-26-2010, 06:00 PM
  5. aluminum tig welds w/ 250P
    By bmichaelk in forum Customer Testimonials
    Last Post: 03-31-2009, 03:48 PM
