Results 1 to 19 of 19
Thread: Advice on a tig welder
  1. Default
    Trying to teach myself how to tig. Mainly steel what to you think of the powerarc 280
    If you just want to do steel, you can start off with your PA300. You will learn a lot and will know more about what you want in a TIG machine. Everlast has some videos showing a TIG setup on the PA300 on their YouTube channel.
    I have done some tig with the powerarc 140. Lift start tig
    I am looking to have more control and options
    I would look at an AC/DC machine if you want to get into TIG beyond just a basic setup.
    if you are not going to be into tig welding aluminum . I would not get the ac dc machine. They are much pricier than you need. Any of Everlasts machines that has HF start will work fine. You will in liklyhood not ever weld on any ferrous metal at anything over 200 amps. If you want a do anything machine that can weld copper or alum. get the ac dc machine 250 amp.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    What about the powerarc 280. Is that a good tig welder ?
  1. Advice on new 255ext set up
    By Dedvetpath in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-01-2016, 02:32 PM
  2. Need advice. Striking an Arc. PowerArc200
    By Kansan in forum Stick Welding (SMAW)
    Last Post: 03-26-2015, 11:43 PM
  3. Some advice for the beginner
    By Beginner in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-05-2014, 04:47 AM
  4. Possible project ... need advice
    By Oleg in forum Personal Projects (no welder required)
    Last Post: 02-16-2012, 07:15 AM
  5. New Meber Intro and Looking For Advice
    By metallurgist in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 07-06-2011, 04:22 PM
