Results 1 to 8 of 8
Thread: powerplasma owners post up
    Default powerplasma owners post up
    If you currently own or have owned one let's hear your experience good, bad or ugly. Consumable life, cut quality, overall build. Maybe some pics of projects done with your powerplasma.
    I have owned a PP60 with a P80 torch (High Freq) for several years and it's been flawless.
    Consumable life has been about one set per year for my more than average hobby work.
    Here are some pictures of cuts in 11ga cold roll and a project with 3 pieces cut from 1/4 x 3 cold roll steel. http://www.everlastgenerators.com/fo...-Plasma-Cutter
ID:	12996Click image for larger version.
ID:	12997Click image for larger version.
ID:	12998Click image for larger version.
ID:	12999Click image for larger version.
ID:	13000Click image for larger version.
    A good air drier like the Motor Guard M60 is a must have for clean cuts and long consumable life.
    Nice clean cuts!
    We do have a "new" generation of machines either freshly rolled out or on the way. They'll look very similar to the past units from last year, but feature new torches all the way around (some were already phased in) and improved internals. Better operation of course too.
    I have had a PP60 for about a year and a half. I use it for field work. I have gone through about 4 tips in that time. I do not use it every day but defiantly every week. It has worked well and runs great off my gas drive welder. I will say that I do not use it for metal heavier than 5/8. It can cut thicker but I find that it is slow for heavy cuts.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
    interesting. Care to elaborate?
    They will have the PT80 torch on the PP 80. The PP 50 has the new PT 60 torch. Pilot arc operation has been improved as well.
    Nice. Looks like the PT80 has a shielded (drag cut) cap for 40-70 amps? Definitely a cool option.
  1. New Owners manuals
    By emoelectric in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-03-2018, 08:38 AM
  2. Owners Manual for MTS 211si
    By johnsund in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-15-2017, 07:10 PM
  3. I-275P USA owners Manual
    By Baronsbest in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 05-22-2016, 02:16 AM
  4. PowerMTS 251Si owners I need your help.
    By seaarc24 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 11-05-2015, 02:49 AM
  5. New Owners manuals
    By emoelectric in forum Forum related Questions
    Last Post: 04-24-2009, 02:17 AM
