Results 1 to 3 of 3
Thread: Symptoms of spark gap being too large? Is it just hard starting?
  1. Default Symptoms of spark gap being too large? Is it just hard starting?
    I think I need to take a look at the spark gap distance in our 200dx. It has been getting harder and harder to get the arc started on AC. Just wondering if a large spark gap can affect the arc once you are welding?
    Also do I just take the front cover off the machine to gain access the the components?
    Peter
    Correct, the point gap is just used for starting, it doesn't affect welding. Most units come apart from the rear panel and top cover.
    clean point surface and sharp edge on points, flat surface, not domed.
  1. Spark Container
    By Gerry in forum Everlast Plasma Cutters (PAC)
    Last Post: 12-10-2012, 06:50 PM
  2. Spark Gap Contacts
    Last Post: 10-03-2012, 12:50 AM
  3. Hard tig arc starting using pulse when restarting a bead
    Last Post: 10-09-2011, 08:37 AM
  4. Got a spark, but no cut, not an Everlast unit though.
    By CSR in forum Everlast Plasma Cutters (PAC)
    Last Post: 09-08-2010, 04:14 PM
  5. PowerPlasma 50 problem - Spark but no HF arc
    By Kapoor in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-29-2009, 08:35 PM
