Results 1 to 3 of 3
Thread: Everlast MTS 200 1 lb. Spool Adapter
  1. Default Everlast MTS 200 1 lb. Spool Adapter
    Here are some photos and drawings to construct a 1 pound wire spool adapter that I made for my Everlast MTS 200. I used a 2" schedule 40 galvanized pipe nipple from Home Depot and cut it to length, and some 1X3/16" cold rolled steel for the flat bracket. It works great I you have to use the small wire spools.
Name:	Spool adapter 1.jpg
ID:	12962Click image for larger version.
Name:	Spool adapter 2.jpg
ID:	12963Click image for larger version.
Name:	Spool adapter 3.jpg
ID:	12960Click image for larger version.
Name:	Spool adapter 4.jpg
ID:	12961Click image for larger version.
Name:	Spool adapter 5.jpg
ID:	12958Click image for larger version.
Name:	Spool adapter 6.jpg
ID:	12959Click image for larger version.
Name:	Spool adapter 7.jpg
ID:	12956Click image for larger version.
Name:	Spool adapter 8.jpg
    Looks like you could just remove #15 and run the 1lb spool on the shaft in normal fashion. Click image for larger version.
    I tried that but the resin material that they use is so brittle that it that it broke the bushing. American units that I use at work use a PVC plastic that is very durable. It took Everlast over two months to send a new part. I ended up fabing a bushing from steel while waiting. Also the adapter is a much faster way of changing spools. Another point is that the welder is not designed for the small spools even though one brochure states that is is. I called their tech support and they stated that it is not designed to accept the small spools.
  1. Adapter for weld tec
    By Steves1967 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 01-06-2018, 04:37 PM
  2. dinse adapter for 210ext
    By miker2 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-06-2012, 03:39 AM
  3. adapter for new tig torch
    Last Post: 07-02-2011, 11:34 PM
  4. PowerArc used with Tig power adapter??
    By Oxide00 in forum Stick Welding (SMAW)
    Last Post: 06-06-2011, 07:44 AM
    Last Post: 08-10-2010, 07:46 PM
