Results 1 to 2 of 2
Thread: Tiedown points
    Angry Tiedown points
    Made a couple of tiedown points for a Kubota L3200. Pretty much a copy of a style that some company made before they went out of business. Nothing special, but will do the job. One small snag was that I measured the bolt spacing at night and only checked the one side where I could kinda see. Turns out the spacing is different on each side, so I had to make another plate with the correct spacing. Something about measure twice, cut five times and it's still too short? Doh!
    Oh well, came out ok in the end, and I no longer have to worry about where the chains are being attached. Glued them up with 7014. I added some anchor shackles, for tie downs, in the back a long time ago, but hadn't done anything up front. Rounded it out with new transport chain and screw type binders. Slowly retrofitting all the trailers with this type of system. The binders are attached to the trailer D rings with anchor shackles, so they stay attached and hopefully don't get lost or damaged quite as fast.
ID:	12842 Click image for larger version.
ID:	12843 Click image for larger version.
ID:	12844 Click image for larger version.
    Nice job I just tie mine off at the rear differential housing and front bumper.
    Lincoln A/C 225
    Everlast P/A 200
  1. Did i-Tig 201 have points changed recently?
    By aland in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-26-2018, 01:46 PM
  2. HF Start Points Adjustment on Powertig 200DX Dual Voltage
    By MBfrontier in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-25-2014, 02:03 PM
  3. Points location and other potential problems to check.
    By Mad-Dax in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-15-2013, 05:41 PM
  4. Do the HF points need to be ajusted
    Last Post: 06-01-2011, 06:45 PM
