Results 1 to 14 of 14
Thread: Welding table overhaul
    Default Welding table overhaul
    I decided to to a over haul on my welding table, right now it is 3'x6' and I'm gonna make it 3'x4' to gain some space back in the garage one section is 3/8" oiled and pickled plate the other part is a t-slot table from a big knee mill, I am going to incorporate the receiver style accessory ports and possibly cut slots in the plate like the jmr table. All I have done at this point is rough out the legs
ID:	12709Click image for larger version.
ID:	12710Click image for larger version.
ID:	12711Click image for larger version.
    To make the legs I cut apart a 4x4 left over from a project
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Leveling feet I am going to use
    LONGEVITY 250EX Tig
    Why not put it on locking casters so you can roll it out of the way when need be ?
    I use these 5" total locking ones on my welding table... 300lbs capacity each and cost about $7 when I bought them a few years ago. Weld a nut onto the backside of the mounting tab and you can level it with a washer if needed.
    Table progress
    LONGEVITY 250EX Tig
    Almost doneClick image for larger version.
ID:	12762Click image for larger version.
    LONGEVITY 250EX Tig
    Caster plates cut from 1/4"
    LONGEVITY 250EX Tig
    LONGEVITY 250EX Tig
    Started building accessory ports
    LONGEVITY 250EX Tig
    Vise mount
    Made the vise greasable
    LONGEVITY 250EX Tig
    The two most important days in your life are the day you are born and the day you find out why.
    Mark Twain
    LONGEVITY 250EX Tig
    Made gussets for the vise mount
    LONGEVITY 250EX Tig
    Picked up aluminum diamond plate for the lower shelf
    LONGEVITY 250EX Tig
    Table progress and added 4' led lights
    LONGEVITY 250EX Tig
    Goofing around with picture features
    LONGEVITY 250EX Tig
  1. Tig Welding Table
    By knock10090 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-22-2015, 04:17 AM
  2. Welding table
    Last Post: 02-26-2014, 01:30 PM
  3. New 4' x 6' Welding Table
    Last Post: 07-16-2013, 03:23 PM
  4. My Little Welding Table
    By RP62 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-06-2012, 01:58 PM
  5. Project 4 from I_Love_Plasma ~ Slab Carrier Overhaul
    By I_Love_Plasma in forum Heavy Equipment and Commercial Projects
    Last Post: 10-25-2011, 02:47 AM
