Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Cummins turbo mount
    That'll be pretty nice but I think you're gonna need some sound deadening material.
    Agreed I will be putting son on the fire an under hood the linex should take care of the inside
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Ordered the pistons, 17.3 compression ratio marine grade should be here soon
    LONGEVITY 250EX Tig
    Will you still have air conditioning ?
    Pistons showed up
    LONGEVITY 250EX Tig
    Yep!
    LONGEVITY 250EX Tig
    Quote Originally Posted by dzljon View Post
    Pistons showed up
    Have you considered total seal gapless rings ? I've built gas engines with them and luv em. They should keep the oil very clean with no blow by.
    New pistons
    LONGEVITY 250EX Tig
  8. #28
    We are back on the jeep Cummins projectName:  20160110_165915.jpg
Size:  157 BytesName:  20160110_165915.jpg
    LONGEVITY 250EX Tig
    Attached Images Attached Images
    LONGEVITY 250EX Tig
  10. #30
    Effort = Reward
  11. #31
    https://youtu.be/SCFTmxWHPgw
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    LONGEVITY 250EX Tig
  12. #32
    Spent some time deployed and now we are back on this
    LONGEVITY 250EX Tig
  13. #33
    Machined the crank sensor pulse pattern into the 4bt cummins harmonic balancer so the stock jeep tj tach will work
    LONGEVITY 250EX Tig
  14. #34
    Turbo progress
    LONGEVITY 250EX Tig
  15. #35
    Looking good!
    Purple Fabricator 211i
  1. 4bt Cummins motor mounts
    By dzljon in forum Other Custom Fabrications
    Last Post: 08-31-2016, 07:14 AM
  2. York 210 mount
    Last Post: 10-04-2015, 06:08 PM
  3. Cummins exhaust manifold cut to fit
    Last Post: 11-19-2014, 09:56 PM
  4. 1936 Ford Schoolbus with Cummins 5.9 NV4500
    By Tacoma747 in forum On Road Fabrication
    Last Post: 08-20-2013, 09:27 PM
  5. Jerry can mount
    By Krookz in forum Other Custom Fabrications
    Last Post: 03-03-2011, 01:06 AM
