Hey guys,
I purchased a Powertig 185 a month ago and have just recently gotten around to using it more. Only thing I don't like is the argon comes out of the torch in a big "whoosh" when I first start the arc, then it settles down. I realize that some preflow is necessary, but what I am experiencing seems excessive and a waste of gas.
I've tried shortening the gas supply hose that came with the welder down to about 14", but I'm still having the issue. Will another type of hose fix this issue, or do I need some sort of flow restrictor?
I'm using a Victor HRF 1480-580 flowmeter regulator....believe the delivery pressure setting is 25 psi.
Thanks for any help you all might be able to provide.
