Results 1 to 18 of 18
Thread: PP 80s on a torchmate
    Default PP 80s on a torchmate
    Doing some cutting on the torchmate tonightClick image for larger version.
ID:	12474Click image for larger version.
ID:	12475Click image for larger version.
ID:	12476Click image for larger version.
ID:	12477Click image for larger version.
ID:	12478Click image for larger version.
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Very nice. How bad was the cleanup? It is nice you can make your own parts. Did torchmate come with controller and software?
    That's really good work. Oleg forwarded me pictures of that last you night. If you can, post up the consumable size, material thickness, amp used, thc or not, speed etc. and the details about what it is and why it's needed ( for conversion I believe) for others reading interest.
    IF you can swing it, I'd suggest getting the machine torch as performance should be better.
    Thanks! The torchmate came with everything but the computer and cutter.
    LONGEVITY 250EX Tig
    This part allows the factory tach in ford trucks work with a cummins engine, metal is 3/16, cut rate was 40 ipm, at 45 amps, no torch height control, consumables are 1.0 tip for the s75 torch. I am looking to getthe machine torch in the future. Thank you for the questions.
    LONGEVITY 250EX Tig
    Very impressive work. After cutting and clean up did you have to balance it, like you would for a boat prop?
    Quote Originally Posted by dzljon View Post
    What's the price ? I couldn't find any pricing at their website.
    Thanks!No balanceing required for this applcation
    LONGEVITY 250EX Tig
    Best thing to doi s give them a call, because of all the options prices a different
    LONGEVITY 250EX Tig
    Was the the part was in their library or on the net? How was the learning curve on the software?
    i had to draw the whole part, spent about 45 minutes drawing it and about 3 minutes cutting each one, the soft ware is pretty easy ince you rap your mind around the terminology, but they have a awsome customer support center to help you with any issues, or questions, thye know the machines and software very well
    LONGEVITY 250EX Tig
    Pretty slick. So you drew it in their cad/editor. And then sent it to cut? If so, slick. So you added computer and plasma cutter and you were running? How bad was assembly? I looked at the 2x2 but never bought. Sounds like it was pretty straight forward.
ID:	12484Click image for larger version.
    This is my work space for plasma cutting
    LONGEVITY 250EX Tig
    That would work for me.. Little tight but nice, that is how we work here. So the software was not too bad, or their support is really good. is that a 2x4? Mind PMing price breakdown LOL. Nice thing is, over time it will pay for itself.
    Cut 1/2" at 20 ipmClick image for larger version.
ID:	12497Click image for larger version.
ID:	12498Click image for larger version.
    LONGEVITY 250EX Tig
    Close up on 3/16
    LONGEVITY 250EX Tig
    3/16 sheet used on my caster wheel project
    LONGEVITY 250EX Tig
    This is a biocide and corrosion fighter for the plasma water table
    LONGEVITY 250EX Tig
  1. Torchmate AVHC with PP60s
    By FeddFab in forum Everlast Plasma Cutters (PAC)
    Last Post: 01-04-2015, 07:27 PM
  2. Plasma & Torchmate
    By worntorn in forum Everlast Plasma Cutters (PAC)
    Last Post: 07-05-2011, 03:52 AM
  3. Power Plasma 50 & Torchmate 2 x2
    By geezer in forum Everlast Plasma Cutters (PAC)
    Last Post: 08-08-2010, 05:47 PM
