Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
Thread: Welding cart advice?
  1. #41
    Right now. I finished welding the cart. Sanded it down. Note: Don't buy HF brand Sand Paper. Garbage doesn't last. Even with hand use. And I use the one listed for Metal. Sprayed a coating of Rustoleum Primer on the top and sides. Waiting for it to dry before I spray underneath. Haven't decided on a color. Maybe a Medium Gray?
    Smoothing welds is a job for a flap disc. You will tear up most any sandpaper, even most emery cloth.
  2. #42
    Aug 2014
    I was just sanding the surfaces.
  3. #43
    Try scotchbrite for general paint prep, if you are doing it by hand.
  4. #44
    Ditto on the flap wheel. More expensive that grinder wheel but I like them better.
  5. #45
    Aug 2014
    I have a few of them. Different Grits. Found some Dewalt brand 120 at Amazon. Ordered them back awhile ago. I may order more.
    This project has Almost used a 2 Pound roll of .030" Lincoln L56. There might be 1/4 to 1/2 Pound leftover. Only about 300 PSI in the tank. Put some Rustoleum primer on it to protect it. I may not be able to paint it. Starting to get a little chilly out. And rain most of the week. Besides, Haven't decided on a color yet. Maybe a Semi-Gloss Black or Medium Gray. To help hide some of the imperfections.
    ......Besides, Haven't decided on a color yet. Maybe a Semi-Gloss Black or Medium Gray. To help hide some of the imperfections.
    Maybe Everlast Green?
    Just make sure it's not Red or Blue.
    rivets
  7. #47
    Aug 2014
    Primed. Waiting for it to dry. Its upside down at the moment. I did get two cans of RustOleum Sail Blue. I could have gotten Magic (I think the name was) brand JD/ Sfety Green. But figured that would be too much Green on Green. Just need to drill the holes for the Safety Chain.
  8. #48
    My carts are black, not flat. And my welders are green. Works great me me. A dark blue would look good too. But I agree on too much green.
  9. #49
    Aug 2014
ID:	12468Click image for larger version.
  10. #50
    Just add the decals?
  11. #51
    That's not dark enough. I used to have stuff that color Not sure what would happened if you put a green unit on a cart that blue. hahahaha.. Stand back..
  12. #52
    Aug 2014
    TSC on Sale. $3.99 can. Not much selection. I could have gotten Orange, Red, Hunter Green, Gloss black. Only had one can of a Medium Gray.
    OH well. I could always sand it and paint over it later.
  13. #53
    Get a few cans and go camo. hahaha..
  14. #54
    Aug 2014
    All Finished. Just drying. now. I can still smell the paint. Click image for larger version.
ID:	12470Click image for larger version.
ID:	12471Click image for larger version.
  15. #55
    Looks good. Looks a lot like mine, other than I have more space in the middle (for a Plasma and two TIGs on it). Also I have a lift up and down handle. And mine is Henry Ford favorite color.
  16. #56
    Aug 2014
    Thanks. I only really needed a more basic unit. Its only for a Mig.
    I used 5/6" U-Bolts. Threads weren't long enough. Had to use a Die to cut a few more. This way I was able to use a nut on the bottom. To help lock them in place. The Swivel Casters were mounted in a little bit. This way the front wheels don't extend past the frame. The rear casters(Fixed) are underneath the 1/8" plate to handle the weight of the tank and cart. The 1/8" Thick Sq. Tubing was used on the rear legs for extra strength. Height is 27", Depth is 30", Width is 12" (14" on the rear plate)
    I would've liked to have had a Drawer to store small items in.
  17. #57
    Aug 2014
    Its actually pretty easy to roll. Even with all the weight on it. Maybe I should've made it a little taller.
  18. #58
    Looks nice. How about a picture of it all loaded up? One minor point, it's not a great idea to hang cables over small hooks like your U bolts. It can damage them over time, because they will exceed their minimum bend radius. This is true of all cables, but particularly with MIG guns, as they have moving parts inside.
    You can always add a drawer at a later date. There are all kinds of add on drawers for things that you can adapt.
  19. #59
    Aug 2014
ID:	12517[/attach]Click image for larger version.
ID:	12515Click image for larger version.
  3. Advice on Welding HF Trailer Kit
    By EmptyNester in forum General Welding Questions
    Last Post: 09-23-2011, 11:01 AM
  4. Welding cart
    Last Post: 01-03-2010, 02:50 PM
