Thread: Power Cool W300 Dual Voltage Dimensions
    Default Power Cool W300 Dual Voltage Dimensions
    What is the height of the Power Cool W300 Dual Voltage water cooler? I am building a welding cart for my Everlast 200DX Dual Voltage and want to make sure the shelve spacing is adequate for the water cooler when I add that in the future. The dimensions shown in the manual don't specify which dimension is the height. Your help is appreciated.
    ThermalArc 181i
    Lincoln ProCut 25
    Victor O/A Torch
    Jackson Pro Variable
    10" wide x 14" tall x 18" long.
    Including the handle or not?
    Don't know about that.
    The dimension should be with the handle, but you can't trust the dimensions listed anywhere in the manuals or brochures, or even the dimensions listed on the forum (unless it's a hand measured dimension of the exact unit you have). I almost stitched a cover for my 250EX before I received the welder from Everlast, but if I had done that, the cover would have been off by over 3" in length!
    My welder is right around 21-1/2" and it's listed as 25" (rounded to the nearest inch) in the manual, so proceed with caution. If you're cutting it close on dimensions, ask someone for the dimensions of their unit () so you know if it will fit or not.
    Thanks for the replies. I'll make it 18 inches to make sure I have room.
    ThermalArc 181i
    Lincoln ProCut 25
    Victor O/A Torch
  1. Power Tig 200DX Dual Voltage Maintenance
    Last Post: 07-05-2014, 01:39 PM
  2. Power Tig 185 Dual Voltage / my first time welding
    By CMJ in forum General Welder Questions
    Last Post: 06-26-2012, 05:59 AM
  3. Power Cool W300 motor
    By rengaw21001 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-04-2011, 01:31 AM
  4. Better pics of Power Cool W300
    By Slick in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 04-27-2011, 01:22 AM
