Thread: How big of Rotary Phase Converter needed to run 3phase 315lx tig welder on one phase?
  1. Default
    Call your electricity provider and see if they can bring 3 phase, I have three phase at home!
    PowerARC 300
    I would not use a rotary phase converter with a welder. If you do you would need a 15 hp rotary converter to do a decent job with it. Rotorys do not make very good power. I have a Phaseperfect digital converter and it will run any kind of 3 phase load but they are costly. I have a hydra shift lathe with a 7.5 hp motor and I would have needed a 15hp rotary converter to run it well. A 10hp minimum but there would have been limitations with it. I believe the smallest Phase perfect is 10 hp and it is about $3000. To me any welder under 300 amps there is no need for 3 phase. Even most industrial welders run 440 single phase. A rotary converter will about double your electrical usage for a given load. A phase perfect is 97-99% efficient and continually corrects for unity power.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
  1. Everlast Welders on 208 3-phase - converted to single phase
    By IronFreak in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-01-2016, 08:45 PM
  2. 250ex Three Phase
    By Cippee in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-15-2012, 05:27 AM
  3. Question on 300 amp class AC/DC TIG machines and single phase
    Last Post: 01-05-2012, 01:46 AM
  4. Running a 1-phase 240V welder off 3-phase 240V power receptacle?
    Last Post: 06-21-2011, 03:07 AM
  5. Wiring the 3 phase EX to single phase 220VAC
    Last Post: 02-24-2010, 04:37 PM
