Thread: modified harbor freight cart
    Default modified harbor freight cart
    I made an extension panel to fit the machines and bent tubing for handles, bought the carts for $35 each
ID:	12136Click image for larger version.
ID:	12137Click image for larger version.
ID:	12138Click image for larger version.
    I should do something similar to mine. The tray isn;t big enough for the 200dx. I could fit my PT185 on it, but don;t really use a cart with it.
    Cool. How did you bent the tubing? What machine do you have on top? How sturdy/stable is the HF cart with the welder, water cooler and large tank on it?
    Joe
    CH 110 mig/flux
    Looking to step up to Everlast tig
    Aug 2014
    I looked at one at my local HF. Wasn't impressed with the Strength of the unit. Felt flimsy. The one I saw had 3 levels. I would like to build one. But don't have much metal working tools. Just some handheld power tools, 8" drill press, Etc.
    Plenty of nice carts have been built with nothing more than an angle grinder and a welder. Even a $10 HF cheapy can do the job.
    Quote Originally Posted by jetjoe View Post
    thanks! I bent the tubing with a bender I made using the pro-tools 105 dies it is sturdy enough to hold my welder since in my case it does not move far, I currently use a 25' weldcraft crafter series cs310 torch so it reaches most jobs with no problem I also put a 25' ground on also. the tig machine is a powertig 210EXT and the other is a powerplasma 80s.
  1. Harbor Freight Welding Cart
    By Depdog in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-05-2018, 05:30 PM
  2. $39 Harbor Freight tungsten sharpener
    By DaveBonds in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 03-22-2014, 12:35 PM
  3. modified my cart
    By single t gt in forum Other Custom Fabrications
    Last Post: 04-17-2011, 10:36 PM
