Results 1 to 12 of 12
Thread: Plasma on my PP256 stopped working
  1. Default Plasma on my PP256 stopped working
    Hi all. Greetings from Downunder.
    First up a big thanks to Mike for letting me in, I've been avidly reading and waiting to post up my issue as being without my plasma has left me in a state of complete disarray.
    I've had my PP256 for about 4 or so years now, it's mostly been used in my home workshop for TIG and stick welding and has performed flawlessly. About 6 months back I decided to build a CNC table for the plasma and use it to cut out various small parts - mostly sheet steel parts and small flanges for superchargers out of 5/6mm mild steel. It's been working great with no real issues.
    Earlier this week I started to cut out some flanges out of stainless. I had a few issues with setup as it behaves a lot different to mild steel but in the end I managed to get some reasonable cuts by slowing the cut speed a little. With the machine set up I took a break overnight and retuned to start cutting in anger the next day. After making one cut the machine would no longer cut. I tried and tried again but no go.
    I discovered the forums here and set about reading through the various similar issues and trying to diagnose the problem. Here's hat I have tried...
    I tried new consumables - no luck
    Checked earth connection to workpiece - ok
    Check resistance of earth lead - ok
    Check resistance of arc start lead - ok
    Checked insulation between arc start and torch nozzle - ok
    Checked and reset HF point gap to .030" (was more or less .030" before)
    Tried scratch starting - did not work
    Checked all my settings - DC + 2T + Cut + Pulse off + everything except amps turned back to zero - still no joy
    Check air pressure - showing 60psi on regulator when cutting - I even tried a variety of higher and lower air pressures - still no joy.
    I checked all plug in connections inside the unit and found none loose or disconnected.
    I checked all components and none appeared to be burned or damaged.
    I also tried using unit in TIG mode - it works perfectly with no issue on HF start at all.
    After exhausting everything that I could find in the forums I am a bit stumped and have run out of things to try.
    If I look at the end of the torch when I try to start the arc I can see the spark jumping inside the nozzle and every now and then it appears to have a minute almost invisible pilot arc (about 1/4" long and barely visible) but it will not create the full pilot arc.
    Not really sure what could have caused the issue. I don't believe that I exceeded the duty cycle, although this is I guess a possibility. Only other contributing factor that may be related is that the unit was switched between STICK and CUT a few times when the unit had a start signal from the CNC controller (basically the same as holding the trigger down and switching between modes).
    I was unable to locate a machine style torch and use the 60 Amp style HF torch mounted to the CNC. I have not tried a new torch on the unit although this appears to be fine. I did however remove the torch from the CNC to carry out the tests.
    Only other observations are that with the unit turned on but in idle there is one red LED lit on the RHS of the top board. When the unit is 'cutting' a whole bunch of red and green LEDS light up. Not really sure what these mean, perhaps these give some indication of what is wrong? I'm really at a loss as to what to try next. Any help would be greatly appreciated. I know ultimately that the unit is probably a little unsuited for the use I have, but until I can raise funds for a dedicated unit it is all I have. I have an electrical / electronics background so if any test need to be carried out I have a muti-meter at the ready.
    Thanks in advance.
    DM
    Sorry to hear you're having problems. When you try to cut, what does the display do?
    One thing you might check is to disconnect the torch and check resistance between the pilot arc wire and the dinse plug. Not a likely problem with what you have mentioned, but you didn't mention checking for shorts, just opens.
    It sounds like you can see the HF arc, but the transfer to pilot arc isn't happening. Running that unit on a CNC is probably over the designed duty cycle, unless you cut small parts and let it rest between parts. That and switching modes under load make me think that you have probably killed something. Ray might be able to give you some detailed tests to confirm what the issue is.
    Thanks for the reply.
    The parts are only small and only cut one at a a time although I concede that its possible that the slower cut speed might have just pushed things over the edge. That said I would expect the machine to go out on over-current / overheat rather than completely give up.
    The display changes from the set amps - e.g. 50 down to 29 when I operate the torch.
    I think that this shows as open circuit, although I will go and and check.
    Yes I agree - my explanation / understanding of the correct terminology was probably not correct
    I will go and check the resistance between the dinse plug and the pilot arc wire and report back.
    DM
    There's no short between the dinse and the pilot arc wire.
    One other thing, which I assume is correct although I will admit baffles me, is that there is no continuity between the dinse plug and the torch - the air line is not conductive - I assume that somehow the air acts as the circuit?? Is that correct?!?!
    DM
    Quote Originally Posted by DeeEmm View Post
    DM
    No, there's a copper braid in there.
    Okay, will go check that. Might be my issue.
    My Bad. Yes there is continuity between the dinse and the torch electrode.
    Damn, and there was me thinking it could be an easy fix
    DM
    OK. I'm fresh out of ideas.
    If anyone has any suggestions it'd be great to hear them.
    Thanks in advance.
    DM
    This is after the fact, but the 256 should not be used for CNC under ANY circumstances. It is not designed for that work. Although a few for a time were shipped with CNC adapters, which was a mistake, and we did not advertise it to be sold as such.
    Call Bob there in Australia. He'll give you a hand.
    Hi Mark,
    Where can I find Bobs details?
    Have had no issue with HF start at all. Seems some experience issues whilst others don't. Hasn't been an issue here, machine works great.
    On the website. And in the manuals.
    Hi Mark.
    I bought my unit direct from the states, only details in there lead me right here.
    There's three numbers listed on the Aussie website, Sydney, Port Macquarie and a mobile number.
    Any clue which is Bobs?
  1. Plasma stopped working on PowerPro 205
    By mak in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-12-2020, 12:29 AM
  2. Power Ultra 205 HF start has stopped working
    By KC TB in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 02-02-2018, 03:14 AM
  3. PP256 Plasma stopped working
    By Andy in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 10-10-2013, 12:34 AM
  4. Pedal stopped working PP256
    By Timberwolf in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 06-08-2011, 04:42 AM
  5. my 250 EX stopped working
    By Rodsmachineshop in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-06-2010, 06:00 AM
