Hi, Jonathan.
If your unit came with a quick-disconnect fitting on the gas inlet, check to make sure it's fully connected on the machine. I've had times that I thought the coupling was fastened when it wasn't. Also, some torches have valves in the handle (but probably not if you're using the torch that came with it).
