Quote Originally Posted by Glassbeaver View Post
To the op, what you're describing sounds like a gas issue. Frequency is way off to(120ish). Welding outside?
Everlast 200DX (Dual Voltage)
Northern Tool Dry Cut Saw
Thanks, i will definitely make the adjustments and give it a try.
I was welding in a shop, but I did think my gas setup was way off, when realizing afterwards the reg is not gauged in cfh.
Will get some time tomorrow to check it out and will hopefully make some improvements.
