Results 1 to 8 of 8
Thread: 1/16 aluminum plate to 3/8 aluminum bar...HOW?
  1. Default
    WOW! jakeru has described that Very well (almost felt like I was seeing it )
    I would just add two things. I would "lean" the torch towards the 3/8ths piece, concentrate the heat on IT, maybe start the weld on that side and once a puddle is established there, run it to the 1/16th and proceed like that the whole way.
    And, with Aluminum in general, the problem we have is that it takes a "practiced eye" to recognize when things are just starting to go wrong (unlike steel where you get a color change towards White and "sparkling"). Things happen Fast, too much heat in the piece has accumulated as you get to a place where it's no longer being dissipated or it's just "built-up" and backing-off the Amps alone isn't gonna save it... But Filler Rod might! Be prepared to stuff 1-1/2" of rod into the puddle at any time! -hehehe...
    drill a couple holes in the 1/16 plate in line with where you want it attached to the 3/8 round stock. Then just weld the hole shut making sure you melt the weld into the 3/8 so that they are welded together . 2 holes should hold it together as good as bolting it.
    Miller 302 gas drive
    millermatic 200 mig
    2014 Everlast PP60S plasma
    thermal arc 250 GTS inverter
    2016 Everlast 250EX
    miller tig cooler
    2015 Everlast MTS250S
    Miller 30A spool Gun
    Linde CM 85 shape cutter
  1. Anodized Aluminum Diamond Plate
    By Buggy Chief in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-13-2012, 10:56 AM
  2. Replies: 8
    Last Post: 11-10-2011, 06:30 AM
  3. Replies: 2
  4. Aluminum diamond plate flooring, for a fishing boat (jakeru's #10)
    Last Post: 07-15-2011, 03:19 PM
  5. "Ultra Bright Aluminum Cleaner" acid-based aluminum cleaner review
    Last Post: 06-29-2011, 07:02 PM
