Originally Posted by
Paul Moir
Automationdirect will sell you a well regarded 1hp drive for $134 w/ free shipping. A motor from them is similarly priced if you can't find one for free somewhere. The 2hp 1 phase pushes you up to a GS2 which is like $250, so that blows the budget. Treadmill motors are pretty popular on the minilathes but I think it would be pretty wimpy for a 10" SB, and DC speed controls seem to me to be pretty pricey for what they are.
That said, 2hp into a 10" lathe seems like a lot. I would think ~1hp would be plenty. My 10" is only 3/4 hp and I've never come close to stalling it, even in a crash! I do ~90% stainless and sometimes in pretty large diameters. I'll betcha 1/3hp was pretty horrid to use!
Nowadays, drives like the GS1 are super-simple to use. Plug in one side to your power, the other to your motor and set up a few basic parameters. Some of the cool things are that you can (often safely and allowed in the motor's datasheet) run your motor at higher than standard RPM, and mess with torque at lower RPM. Pretty much the only thing "ya gotta know" is not to hook the drive up backwards!
Thanks for posting the web site. I will get a GS1 for a 1 hp motor. I am still trying to scrounge a 3 phase motor. I will not be getting an inverter duty motor. From my investigation it seems that if you stay with 240 volt 3 phase the insulation break down is not a common problem. It is when you are running 440-480 volt on a vfd that it is of the greatest concern. The other thing is cooling for low rpm running. I think I will incorporate a cooling fan into my motor compartment to help keep it cool at lower rpm. I seldom use the lathe for more than a few hours at a time anyway ( of course that might change when I get it working real good since it will be much more usable when I am done). I am not in a big hurry so it might take some time to get the motor as a freebe. If I do not find one in a few months then I will buy new. Its hard to make myself buy one when in the past I have seen dozens of them thrown in dumpsters at the job sites I have been on.
Miller 302 gas drive
millermatic 200 mig
2014 Everlast PP60S plasma
thermal arc 250 GTS inverter
2016 Everlast 250EX
miller tig cooler
2015 Everlast MTS250S
Miller 30A spool Gun
Linde CM 85 shape cutter
