Results 1 to 16 of 16
Thread: Harbor Freight Welding Cart
  1. Default Harbor Freight Welding Cart
    Harbor Freight has their Chicago Electric welding cart on sale for $49.99 ($34.99) if you hunt the coupon.
    I got one for my Powertig 185 that will be here tomorrow. Put it together in about 20 minutes. Will hold 100 lbs, so it should work great. Went together without a hitch.
    http://www.harborfreight.com/catalog...q=Welding+cart
    Glenn
    Coupon good through 1-14-14 Click image for larger version.
    Perfect!
    Glenn
    Quote Originally Posted by Depdog View Post
    $29.99 if you REALLY hunt the coupon.
    25% off is $37.50 ... which coupon are you referring to ?
    There are a few different priced coupons floating around. This might be the lowest.
    There is a newspaper in Salt Lake City that always seems to have the lowest HF coupons, but I don't have a link here, I'll find it when I get home. This might have come from there originally. HF seems to make a habit of having a ton of different prices depending on where the ad is.
    That's deff the cheapest I have seen it.
    Glenn
    Saw a pretty nice New one there today, 3 drawers, hooks on the side for Hoses and a Tank platform in back. Just under $100 ($130 less the 25%) looked OK...
    Quote Originally Posted by Blaster View Post
    Just bought one of the 3 drawer models for my 200dx it works great. And for harbor frieght its well built. With my coupon $114.00 probably gonna buy another one for my plasma cutter when I get it.
    I ordered one off HF website as they couldn't keep them in stock here in Houston. The top was't long enough for my PowerPro 164 so I topped it with some 1/2" plywood. I also mounted the argon cylinder brackets on some 2x4 pieces to move them back and to one side so my air compressor regulator wouldn't hit it. Also put a piece of rubber under the cylinder, slid some old bike innertube around the cylinder chains and mounted some old water hose on the brackets where the cylinder would rub on them. went and bought a tee bracket from the Home Depot lumber dept and installed a 1/4" tee and two ball valves to switch between argon and air. It all worked out pretty good.
ID:	12015Click image for larger version.
ID:	12016Click image for larger version.
    wow that looks like a real nice functional setup, the wood between the cart and welder is excellent.
    im really leaning towards one of these!
    good job !
    Powertig 200DX
    Lincoln 140 mig
    and a whole bunch of tools
    I know this is an old thread, but I just set my system up on the HF Vulcon cart. It lists for $299, but got it with a 25% coupon. Not a cheap cart, but enough space for 3 machines, 2 tanks, and plenty of enclosed storage.
    https://www.flickr.com/gp/david_schober/1576U5
    Quote Originally Posted by dgapilot View Post
    How sturdy is this thing? I've been considering grabbing one but haven't had chance to go by store and see if they have one assembled on display yet. I've got a 280sth and a powermax 30xp. sounds like 280sth should be able to fit according to listed dimensions.
    It doesn't feel top heavy or wobbly with machines up there? What about when you start pulling drawers open?
    I took one of 25% off coupons in there and they wouldn't let me use it on a Vulcan welding cart it says right in the fine print on the coupon cannot use on the purchase of any Vulcan products.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
    Pakmaster 75XL plasma
    Sorry I haven't gotten back about how sturdy it is. So far no problem. Build quality is very good for HF. It took about 1/2 hour to assemble the wheels handles and other stuff, but I expected that. It is much more sturdy than the cheap one they have. Drawers are good with reasonable slides. The top one has lots of dividers for consumables. Hope that helps.
    I think I'll probably just build my own cart I want to use pneumatic tires on it so I can easily roll it on a gravel driveway, but thanks for your feedback on this cart.
    Mark
    Garage stuff
    Everlast 255 EXT
    Miller 251 mig
    30A spool gun
    Miller 211 mig
    Lincoln SP 250 mig
    Lincoln buzz box
    Thermal Dynamics
  1. modified harbor freight cart
    By dzljon in forum Hobyist Projects
    Last Post: 09-15-2014, 01:16 AM
  2. $39 Harbor Freight tungsten sharpener
    By DaveBonds in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 03-22-2014, 12:35 PM
  3. JD2 Model 32 Bender + Harbor Freight Ram
    By Rafael in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 03-01-2013, 01:57 AM
