Results 21 to 40 of 59
Thread: 250DX AC Aluminum Weld Issue
  1. Default
    Quote Originally Posted by dmost View Post
    2% lanth. For aluminum balled, pointed for steel. Nice to know the torches are 6 months warranty. What do I do to swap out the torch? Or swap it out for a CK torch? Does a CK use the same internal hardware?
    Surprised to hear contaminated gas is not uncommon, that's the last thing I'd assume. Pretty sh**ty that's another variable I need to take into consideration now.
    for aluminum balled and for steel pointed? 2 percent lanthanated? can you elaborate on that?
    The issue with contaminated gas accounts for about 85-90% of all complaints.
    Don't use a balled tungsten on AC. Use a pointed one, or a point with a slight truncation on the end, only a slight one is needed if at all for that amount of amperage...Balls destabilize the arc, and not recommended at all. Lanthanated is fine. To get a new torch, just call in to ext 202 and tell them the specifics.
    they may claim bad gas but i am not buying it.
    i use 2 percent lanthanated. my question is is he switching to DCEP to ball his tungsten like the old days? and if so why. this would be a user that i would expect to go the bad gas route.
    hmm can't keep up with the editing.
    Well, when they change cylinders the problem disappears. I see this sometimes several times a month with different customers.
    The customer stated he was using 90% ep, which would ball the tungsten initially...until it was readjusted.
    Actually I was typically would sharpen my tungsten to a point to weld Aluminum but when I was welding today and put the balance to 30% it balled instantly. That didn't happen when I was up in the high %'s. I honestly thought the proper way was to have a balled point. I just tried to weld and it balled so I kept going thinking that was normal.
    Everlast 250EX
    Hobart 140 MIG
    Do you have the torch in the negative side?
    After carefully studying the sideways picture of the welder you posted, you do not...There's a detail about it in the manual with a picture. Always EN for the torch even when you are welding aluminum. Put the torch in the negative (right) side.
    WTF...Ok then. I'll try not to f*** anything else up and report back tomorrow with the results of using my other water cooled torch. I'm using it with only gas I was told that it's good for up to like 150amps.
    Everlast 250EX
    Hobart 140 MIG
    No, do not use it or you will melt it. Whoever told you it was good for 150 amps was wrong! Create a rudimentary cooling system with a water hose and some fittings. Talk about contamination.
    That would be some one in sales when I initially bought the machine told me it was good for 150. Just using a hose and fittings should run roughly like a proper cooling system? Just curious if I should wait for the new torch.
    Everlast 250EX
    Hobart 140 MIG
  11. #31
    I would wait on the new torch. The air you pull in will just mess up the welds.
    If it happens when you get the new torch, Mark's not kidding about contaminated gas. It's the bulk of the calls on contaminated welds, or a back cap loose letting air in (or missing/bad o-ring in the cap).
    The CK is $ but a very nice torch and hose. If you plan on doing a lot of welding, I too recommend it.
    On the water cooling, hook up the hose or tap to it, done it for too many years to count. Get a arc flow (as Mark would say) "about like a water fountain" and just drain it outside the shop or in a sink. See below.
Name:	2013-03-19 17.53.58.jpg
  12. #32
    There's a number of ways to adapt the torch. It doesn't take a lot of flow so you aren't wasting a lot of water.
    Old school shops have done it this way for years. If you've ever walked into an old welding shop there's a water spigot right beside the refrigerator TIG sized welder, and a floor drain right next to it.
    This isn't anything new...and works just fine...especially if you've got some flowers that need watering.
    Ok I'll do that. Seems simple enough. Apparently that's what my boss use to do. I'll post results today or tomorrow. I have a small 60cf tank I'm refilling with argon to test for gas contamination as well. New torch is on its way too.
    Everlast 250EX
    Hobart 140 MIG
  14. #34
    If you suspect bad gas, a refill may not do the trick. A swap would be preferable. Of course, if your supplier is giving you bad gas, even a swap is not guaranteed to fix it. Anyway, best of luck.
    I meant swap. I get my gas from GTS Welco. They just swap empty for full bottles. Although I'll pretty sure 90% of local suppliers all fill from a place in Fairhill, Pa. So hopefully it will tell me something new with another bottle.
    Everlast 250EX
    Hobart 140 MIG
    Well I tried the water cooled torch. Doesn't seem any different as it was before. I guess the next step is to check for bad gas. If I had bad gas would I still be able to weld steel nicely? After I welded some aluminum I threw down some nice beads on steel with no problem. Well here is the picture of the welds.
ID:	11254Click image for larger version.
    Everlast 250EX
    Hobart 140 MIG
  17. #37
    Could you post a picture of the tungsten sticking out of the torch and the steel welds. What was your arc length ?
  18. #38
    Your problem is largely coming from the metal in this picture. You can see the discoloration on the metal in that light. This is not cleaned well, not even close... Whatever is causing the discoloration, whether rust from a piece of steel, or laying in the dirt etc, this piece of metal is not cleaned well enough to start welding.
  19. Default
    i would like to know if those shots of the al welds are all on the same piece of aluminum.
  20. Default
    I went at it with a stainless brush. That's the same level I've cleaned aluminum and welded on other machines perfectly fine.
    Everlast 250EX
    Hobart 140 MIG
  1. How to weld TALL weld beads on 1.6mm thick Aluminum Tube?
  2. Cracked right in the middle of the aluminum weld
    Last Post: 03-24-2011, 07:11 PM
  3. New to Aluminum welding. Need some help with an issue
    By Krookz in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-21-2010, 07:05 AM
  4. non-welder problem, aluminum tube joint issue
    By cmd in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-06-2010, 03:29 PM
    Last Post: 07-21-2010, 10:06 PM
