The major issue with having three phase is simply the expense involved, and in some areas you pay higher commercial rates. Here, if you are using it for farm use, power isn't so bad. A lot of farms have it for running the drive motors on the center pivot irrigation systems. Most is 240 Delta. Our EMC's provide really good power to most locations. Here, my voltage reads 244-247 Volts consistently. The 3 phase systems I have checked on Delta, the high leg reads about 270. We have 480 around, but all systems are delta, not wye.
