Results 1 to 5 of 5
Thread: How to weld TALL weld beads on 1.6mm thick Aluminum Tube?
    A tall bead can be achieved by using smaller filler, with less amps...50 or so. It can also be achieved by using higher AC frequency, and using pulse with a wide separation of pulse peak, and pulse base amps with an 50% setting for time on, and about 1 hertz.
    Why would a tall profile be desirable? Is it a cosmetics thing?
    Since intercooler tubing was mentioned I would guess that the reason might be hose retention.
    I would agree to go to 1/16" filler and tungsten. If you are very consistent you can use your pulser, or you can also just pulse with your foot pedal. You want to add filler while you are at high amperage, pushing as much as the puddle can take, then back off the power to let it freeze, while you move forward. Then repeat. Try not to get too much heat into the part. If it gets too hot, take a break and let things cool off.
  1. 250DX AC Aluminum Weld Issue
    By dmost in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 11-30-2013, 08:04 PM
  2. Vertical Up Tig Weld W/185 Micro on 11 Ga Aluminum
    Last Post: 10-28-2012, 05:02 PM
  3. First Attempt at an Aluminum Fillet Weld
    By blasphemy000 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-11-2012, 10:30 PM
  4. Oxy/Ac weld aluminum for a horse stand
    By beezfun in forum General Welding Questions
    Last Post: 08-28-2011, 09:27 PM
    Last Post: 07-21-2010, 10:06 PM
