Results 1 to 20 of 31
Thread: Received New PowerTig 185 Today
  1. Default Received New PowerTig 185 Today
    Unit came 100% complete, no missing parts or clamps or fittings. It came out of the box in perfect condition and tested out on aluminum using the ssc pedal. Have not tested the torch switch, the DC, or stick function yet.
    The only negative comment I have is regarding the female DNSE connection on the unit for the torch. It is clocked in a position that creates a conflict with the torches gas line and the 7 pin connector. My 250EX had a similar issue, but per the customer service it was an easy fix. Opening the case and rotating the connector is a snap.
    Just verified the manual does specify 25 series DINSE (3/8). This unit came with the 50 series instead. It actually works in my favor though, as I can switch torches with my 250EX.
    Congrats on the new machine! Glad it worked out for you. A 250 EX *and* a PT 185... you've got a lot bases covered, from raw power to portability.
    The torch has a cloth like jacket over the cords rather than that stiff plastic sheathing. It's actually a very nice torch. A/C frequency adjustment is on the low side until you get to about the 1 O-clock position, this is where it begins to sound like 60 hz. The dial does not have incremental markings so you have to guess the settings.
    Thanks! The 250EX is my garage unit and that sucker is awesome. Runs 1/2" 6061 plate like a champ! Can not say enough good things about that machine.
    I run a mobile welding service and have a Miller Trailblazer 301G, Millermatic 140 Auto, and a PowerArc 165 TIG/Stick unit. The 165 is a DC only unit and runs 1/8" 7018 like crazy. It's a nice alternative to the Trailbalzer noise when the customer has the juice available. It's a very small unit, about the size of a toaster, and it TIGs steels with ease.
    Because I don't have AC TIG capability, I've been having to turn away a lot of aluminum business. This is why I purchased the 185. It's a much larger unit though than what I envisioned, but I think it's what I need. Still testing it out as per the Everlast instructions to make sure it's 100%.
    Nils
    Does the foot control still override the panel amperage?
    The foot pedal does override the panel setting, so I need to learn a little more about heat. I'll have to check if the display shows the amperage I'm running. This is a "by the seat of your pants" type unit. AC frequency, balance, pedal amperage, are all set by feel, but for less than a $1000 bucks I think it's just fine.
    I believe it is by far the most tig for the money for ac welding. I need a 110 welder for parts of the shop without 220, but that little quirk with the foot control has kept me from buying one.
    The newer units I believe have a rheostat that's adjustable on the pedal if you buy the pedal. This is the same way that the new TA's and "someother" brand works as well. Not a quirk, but just a feature of a lower priced welder. IF it is as you say, and want a panel control and won't buy the 185 because of it, then simply get the the 200DV. It's got panel amp adjustment, but you pay for it.
    I know that Everlast listens to what their customers say, I can see that by looking at the newer models such as the potentiometers on the front panels would get loose from the plastic wrapping during the boat ride, so they put a plastic protection door on the front panel to stop that. Some did not like the small high frequency start on the 250ex, so they replaced it with one that looks to be good for about 10,000 amps and the list go's on and on.
    I do not mean to complain, its just I think this one little change with the foot control would make them just as popular as the 250ex, and most people on here already know what I think of it. The 185 has too many of the most wanted options to by thrown in with and be considered a cheap welder. IMO
    I just wanted to be heard, I will not bring it up again.
    Well, I just bought both the pedal and the unit and there is no rheostat. The panel override is not really an issue with a good pedal. But, if you do go with the cheaper pedal, amperage control swings quickly from one end to the other and requires a finer touch.
    The AC frequency and balance settings are a bit of a challenge as there are no mid-range markings. Knowing these exact settings, like on the digital units, is a nice feature but hardly mandatory. In the end, you still have to run it to see if it's right or not and then make adjustments if necessary. There's no getting away from this, even with a Dynasty 350DX. But once you have the precise settings figured out it's nice to be able to call them right up, this is the advantage of the more expensive systems.
    Did you buy an SSC? They don't have the control on it.
    I don't know if anybody else does but I stick little thin pieces of pin stripping tape on the face above the ac balance and frequency to be able to repeat weld setups, one color for each different weld setup. I know this sounds hokey, but it works good for me.
    To be honest, just the thought welding on a month long project in a critical area, where there is no room for error with only one potentiometer controlling the weld amperage output would be scary. I have never seen a potentiometer spike that was not being adjusted though.
    If I buy one of these units, I would want to have the large dinse connectors so these 200+ dollar aftermarket torch's from the 250ex will interchange.
    With a 185 amps, this is really a non issue for most people. As for scary, the reason the pedals aren't linear is to achieve maximum control on the low end where it's needed most. When you get up to 100+ amps, 10 or 15 amps one way or the other doesn't make or break a weld if you are a welder worth his/her salt. It's not enough to make a rapid difference in the puddle in aluminum, especially. As for the dinse connectors...the ck torches can come with the 25 series as well.
    Plus with a dual voltage machine you have two ranges for the pedal to work in. If you want to do thin stuff, just run on 120VAC and bingo, you now have a low range pedal.
    Yes, it is the SSC pedal and is very nice. Highly recommend. The tape idea is good. I was just going to take a Sharpie and do little tag'n.
    Using my 250EX, try to match audible frequency. But, I'll play with it before I get too anal about this. A good welder should be able to set-up, and any critical chit deserves test pieces prior to the real deal.
    I want this machine to provide a good stable arc and consistent performance, all the rest is up to me. Been busy and not able to do anymore testing, but maybe tomorrow.
    Thanks for your input, appreciate it!
    Do you have any details on the pot used to tweak the pedal range? I just received a pedal for my 185, but it is an older one with no pot.
  18. Default
    Quote Originally Posted by nils View Post
    I would like to hear more about how it welds up next to the 250ex. The only other 110 units that have extended ac balance, frequency up to 250 and pre-flow are Miller and maybe Lincoln that I know of.
  19. Default
    DC mode is great. Very tight arc with lots of control, was lap welding a 1/4" mild on top of 1/8" mild, and keeping the edge sharp was not a problem.
    The SMAW, stick mode works really well in both AC and DC modes. I was surprised at how well 6010 ran all the way down to 70 amps. My PowerArc hates 6010. but not this baby, and SMAW is a newer mode for this model. In DC it light like a match. AWESOME!
    Still working with the AC GTAW trying to optimize the settings for aluminum.
    My SSC pedal is 25K with no external controls.
    The smaw doesn't output in AC, DC only regardless of where the switch is set. Which power arc do you have?
  1. I have not received my welder yet.
    By metalhobby in forum Pre-sales, Sales and Shipping questions
    Last Post: 05-15-2016, 02:08 AM
  2. I just received my PowerTig 210 EXT
    By aclundwall in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 03-02-2014, 02:08 AM
  3. PA 140ST Received
    By jem5rn in forum Introduce Yourself
    Last Post: 01-18-2013, 01:47 PM
  4. PowerTIG 225LX delivered today...
    Last Post: 03-20-2011, 01:06 AM
  5. Received My PowerArc 200 Today
    By Hoosier Hay Man in forum Stick Welding (SMAW)
    Last Post: 12-04-2010, 05:33 AM
