Results 1 to 1 of 1
Thread: 2013 Summer project #2-Vise Grip modification
    Default 2013 Summer project #2-Vise Grip modification
    So I kept putting off uploading all of my contest photos and projects, and then I realized last night the contest is nearing an end in less then a day...so, here I am (not a minute early!). I thought I would do a few quick and easy projects that will help me out in the shop on a regular basis. I decided to modify some Vise Grips that I had laying around in my tool box. I brought this idea up in another post recently, but for some reason, I made a bunch of tools at work a few years back and now I don't have them....Some of the coworkers there that I worked with indirectly had sticky fingers while others thought that borrowing something meant that they could keep it until you asked for it back, so I really shouldn't be surprised about my missing tools.
    Anyways, this is a couple pairs of Vise grips with a square piece of tubing welded onto the side, which can be used to secure your MIG stinger or TIG torch, AND you can also mount smaller tubing inside of the pockets on the Vise Grips and rig up a base to rest your hands on while you TIG weld out of position . I used round on the last pair I made, but the issue there is if you clamp the pliers sideways (vertical), the pipe or tubing that is used for supporting your hands has a tendency of rotating on you...very annoying!
    Here's video of the project:
    http://www.youtube.com/watch?v=07KOHgOTYFc
Name:	Big c-grips before.jpg
ID:	10923   Click image for larger version.
Name:	big c-grips before 2.jpg
ID:	10924   Click image for larger version.
Name:	Big c-grips  in use.jpg
ID:	10925   Click image for larger version.
  1. Replies: 0
    Last Post: 07-19-2016, 11:59 PM
  2. 2013 Summer Time Contest. June 21- October 1 2013
    Last Post: 04-12-2014, 02:42 AM
  3. 2013 Summer Project #3-Transfer point pliers
    By youngnstudly in forum Other Custom Fabrications
    Last Post: 10-02-2013, 06:20 PM
  4. 2013 summer project #1 - Shop stool
    By youngnstudly in forum Hobyist Projects
    Last Post: 08-07-2013, 06:15 PM
  5. 2013 Summer Project #1 Micro Cart
    By Rambozo in forum Hobyist Projects
    Last Post: 07-09-2013, 12:34 AM
