Thread: F250 air ride install
    Default F250 air ride install
    I installed this in 2012 when I did the cummins engine conversion
ID:	12555   Click image for larger version.
ID:	12556   Click image for larger version.
ID:	12557   Click image for larger version.
ID:	12558   Click image for larger version.
ID:	12560   Click image for larger version.
ID:	12561   Click image for larger version.
ID:	12562   Click image for larger version.
ID:	12563   Click image for larger version.
    LONGEVITY 250EX Tig
    MILLER 211 mig w/spool gun
    SMITHY 1324 mill/lathe
    60 gal. 7.5 hp air compressor
    Here is a shot of the cummins under the hood
    LONGEVITY 250EX Tig
    How do you like the air ride, did it turn out as expected ?
    How much power is the engine making ? Is there an engine conversion kit or did you fab it all ? What transmission are you running ?
    the ride is awsome, getting it dialed in it the hardest part for me. The engine is just over 400 hp and uses a variable turbo it took from a 2012 6.7 when the owner swapped it out, the exhaust brake functions when the throttle pedalis at 0% I am using the ford 4r100 trans, and I did fabricate everything but the trans adapter
    LONGEVITY 250EX Tig
  1. Meyer Snow Plow - Ford Expedition - Mount - Install
    By Rafael in forum Truck, Car and Bike builds
    Last Post: 11-28-2013, 04:06 PM
  2. PU 205 Plug Install Question
    By whipman in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 12-27-2011, 01:50 PM
  3. Snorkel install party specials
    Last Post: 09-21-2011, 03:27 PM
  4. Project #8 From Jason: Transmission Limited Slip Diff Install
    Last Post: 06-15-2011, 11:00 AM
