Results 1 to 20 of 24
Thread: MTS250S Weld Cast Iron and Aluim.
    Default MTS250S Weld Cast Iron and Aluim.
    I weld the broken cast iron cannon that someone dropped off a back of a truck then brought it to me to fix with a little love and care I got it back together used my MTS250S in Tig mode and welded it with Cronatron Cast Iron welding rod.
Name:	weld broken cast iron cannon 1.jpg
ID:	10687Click image for larger version.
Name:	weld broken cast iron cannon 2.jpg
ID:	10688Click image for larger version.
Name:	weld broken cast iron cannon 3.jpg
ID:	10689Click image for larger version.
Name:	weld broken cast iron cannon 4.jpg
ID:	10690Click image for larger version.
Name:	weld broken cast iron cannon 5.jpg
ID:	10691Click image for larger version.
Name:	weld broken cast iron cannon 6.jpg
ID:	10692Click image for larger version.
Name:	weld broken cast iron cannon 7.jpg
    All welded and painted and the customer not to be found phone out of order I might have a new garden toy.
Name:	Fixed and painted 1.jpg
ID:	10694Click image for larger version.
Name:	Fixed and painted 2.jpg
ID:	10695Click image for larger version.
Name:	Fixed and painted 3.jpg
ID:	10696Click image for larger version.
Name:	Fixed and painted 4.jpg
ID:	10697Click image for larger version.
Name:	Fixed and painted 5.jpg
ID:	10698Click image for larger version.
Name:	Fixed and painted 6.jpg
ID:	10699Click image for larger version.
Name:	Fixed and painted 7.jpg
    I used my MTS250S and spool gun to welding out in the rain and wind to fix this dump truck aluminum box with a third hinge in the middle to stop it from pushing out. The factory hinge was weld with a Miller 350P at $8000.00 and me with my Everlast MTS250S and spool gun with no pulse no hot start and the truck was outside not inside. The customer was happy and thought I look the same, he is not a welder. With more practice I thing I can get it close.
Name:	full truck wind and rain..jpg
Name:	Miller 350P 00.00 plus machine.jpg
    Miller $8000.00
Name:	MTS250S 00.00 with spoolgun.jpg
    Everlast MTS250S
    Hope the guy shows up (with cash) to pick up. There's a lot of Civil War history around here, and every now and again you see a cannon in a front yard.
    What parts were aluminum and what parts cast iron?
    The truck is aluminum and the cannon is cast iron.
    Kempy, that aluminum looks like you welded it a bit cold. Was that in spray mode? That's the only way to MIG aluminum...or it won't hold up.
    Mark
    It was close to spray mode but when I was test it on the same material 1/2 on 1/8 inch it blow thru about 2/3 of the way down the hinge but look good up to that point, so I had to turn it down even turning it down the weld did blow out at the top because it was to hot, welding across the top part of the hinge the pressure inside got to high it was seal to keep water out I should have drilled a hole and weld it up later live and learn. Maybe I should have gone to .030 wire not .035.
    The cannon was made just for looks and was never able to fire, right ? Did you ever consider grinding the welds down and trying to match the cast finish ?
    Well I did a little research and most of the Mig aluminum thick to thin use Helium mix. So I mixed a 50/50 argon helium and tried it. That is the way to go with a little practice I think it will weld nicely. I used it in SYN spool mode and up the volts by 1.5 I read on Miller site. The heat is more on the weld with the Helium mix then with 100% argon just need hot start and pulse would be nice also, but that a lot of money buying a pules welder for aluminum from Lincoln or Miller or ???? I will just wait some day Everlast will come out with one I hope.
Name:	mig with helium 50% argon 50% first test Syn Mode.jpg
    When I tipped the barrel down out can a lot of used fire crackers but it is a show piece yes. I did think of grinding the weld but know one has even asked or pointed out the welds they are small and the paint covered up most of it.
    Can you see the welds easily?
    But maybe if I have some time to waste I will grind and repaint it again.
    We have a pulse welder, and have had one. Canada doesn't want to deal in that market. They had one previously, the same basic one we have now. They want to keep welder size down, and don't want that market for shipping cost reasons.
    Mark
    I have a 205P and it will not weld like the welds on the truck will the 250P weld like that and with the spool gun?
    So does the 250P welder switches between a high peak current and a low background current at set times per second.
    The 205P is not heavy enough to weld like that, and is for small diameter wire. I never understood why it was offered. It's barely hot enough to do spray welding. It'll do aluminum though with the thinnest wires. Both the 205P and the 250P switch between High and Low VOLTAGE, not current. Single pulse switches between 20-250Hz. Double pulses usually max out at 5 hertz.
    Pulse spay can be in single pulse or double (pulse on pulse) pulse. Our units are single pulse. What you see there is a product of technique as much as it is anything. That's just a simple stepping motion. It's also likely that the item was welded flat, instead of vertical as well, and attached after the hinges were installed.
    Maybe I only notice because I know where it was broken.
    Mark
    You might be right the welds all on the door look the same but when they welded the two outer hinge parts the weld is different. I copied a picture from Miller pulse welder and it has a similar pattern in flat I could get it some what like that but not welding vertical. I will have to look into the 250P sell the 205P and move up.
    Miller site
Name:	Pulse mig alum top Tig bottom.jpg
    my weld back and forth
Name:	back and forth.jpg
    Looks much more wetted out, for sure. I'd be curious to cut through a section and see how the root penetration was to the two different thicknesses. Did you favor the heavy plate with gun angle?
    This is the best I can do to show you the weld cut. I welded right in the corner 50/50.
Name:	weld helium.jpg
    Looks great to me. I need to purchase a spool gun.
    Looks great. Thanks for the demonstration. The helium seems to make all the difference. Looks like another gas I should keep around. I haven't used it since school, and then the price was a lot more reasonable.
    Zoama585
    You got the 250P how do find the pulse work on it? I is you don't have a spool gun but with it I find it so handy with the 25 ft. line the only thing you have to watch out for is tipping the gun to sharp and the gas line will kink a little and slow the flow down if you put it over your shoulder it works fine.
  1. Cast Iron Car block tig welded
    By Kempy in forum Welding Repairs
    Last Post: 06-20-2023, 10:22 AM
  2. question on welding cast iron
    Last Post: 02-26-2017, 02:18 PM
  3. Cast Iron
    By Estarial in forum General Welding Questions
    Last Post: 07-15-2011, 05:36 PM
  4. bandsaw repair, cast iron
    Last Post: 06-24-2011, 02:29 PM
  5. weldig on cast iron
    By yotarover in forum General Welder Questions
    Last Post: 03-06-2011, 09:50 PM
