Results 1 to 13 of 13
Thread: Fun with copper
  1. Default Fun with copper
    Here are some pictures of tig welding copper. I don't remember all the settings but I did use 12 awg romex for fill. Works great!
    Just playing or do you have a copper project in mind?
    Looks familiar , We had a project with some copper sheets involved for a restaurant and none of the welding dealers could supply us the copper tig rod, We did the same as you did used bare romex ground wire.I guess there is not a large market for copper tig rod so nobody has it in stock.Looks pretty good and actually is the same technique as tig welding brass.
    PowerTig 200DX
    Supercut 50P
    Millermatic 200
    Jet 1340 Lathe
    Jet 20" Drill Press
    Jet 12" Wet Band Saw
    Kalamazoo H7 Bandsaw
    Forward 12,000 lb 4 Post Lift
    I have been playing around with copper to make outdoor accent pieces, as well as maybe a copper sink for my BBQ island, light fixtures, and to just test my skills.
    Copper is really difficult to weld, heat just sucks out of the puddle, and the fill rod wants to stick. Can't wait to get my 250EXT working so I can try pulsing at a higher amperage
    Romex for filler wire. It works!
    When I do copper projects, I use the leftover strip that comes out of my metal shears and shape that into a wire to use as filler rod. It's nice because it's the same copper alloy as the base metals, so when it's ground and polished there's no difference in the color or texture at the seam.
    Good job and keep welding!
    Spike Customs, Inc.
    Fresno, CA 93727
    ph- 559-549-RIDE(7433)
    -Follow me on twitter!-
    Kewl stuff, will have to try that as well. I have quite a few Romex stuff laying around from my house remodeling days.
    Copper wire works great! Mainly because it's oxygen free copper.
    I will have to give this a go! I have a few copper projects that I decided to solder and well I hate soldering copper...lol
    This is where guys list their tools....
    This is where I will link my work.....
    http://s159.photobucket.com/albums/t131/tricklex/
    I've tried welding copper scraps in the past, and I tried again several months back when I first got my Everlast tig, but it has always been hit or miss for me. The really clean copper flat bar welded great with romex wire, but I have also had trouble welding (what I thought was clean copper) with romex.
    My little 160STH was pretty much maxed out on a few of the beads that didn't weld so good, but I was able to back off on the heat with the clean copper and gain control of the puddle. I prepped my copper like I normally prep aluminum (a quick wipe with acetone, followed up with a clean rag). I thought that was enough, but maybe not?
    That's neat and really simple! What setting do you use to weld copper? (DCEN, DECP or AC?)
    Owner/Operator of Breakneckmoto
    Used motorcycles and parts
    Straight polarity (DCEN). It will take a good amount of heat (amps) to get your bead started, but once you do, it won't take near as much to keep the puddle liquified. As with welding aluminum, cleanliness is the key. Obviously you'll need smaller diameter filler rod and a thinner piece of copper if your welder is of limited capacity like my 160STH is.
    The 200DX welded copper romex onto carbon steel nicely. I was thinking of welding an outdoor table that could show off the contrast in color but after welding I could not get that deep color to return. Any help?
    Quote Originally Posted by Tensas View Post
    If you truly melt the steel, then the copper will mix in and get blotchy. Joining copper to steel should be a brazing process, where you don't melt the steel at all, just the copper. It will bond to clean steel, although you might need some flux. Depending on the color you are looking for, there are also many bronze alloys that can be used for this process.
  1. Can you weld copper with your TIG welder?
    By joshuab in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 08-18-2013, 12:54 AM
  2. Copper Butterflies
    By dawjr32223 in forum Metal Art
    Last Post: 01-25-2013, 07:41 PM
  3. Tig Welding Grounding Bar Copper to Steel
    Last Post: 12-12-2012, 06:04 PM
  4. Welding copper and copper alloys
    By Cippee in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-23-2012, 03:50 AM
  5. Thin gauge copper welding
    Last Post: 03-04-2011, 10:16 PM
