Results 1 to 11 of 11
Thread: Great idea!
    Default Great idea!
    I thought this was a great idea so I thought I would share
    Not bad, I wonder if it could be improved so that you don't have to keep bending the spring clamps. I think even the quality ones would weaken and break after several cycles.
    That is a great idea, will have to try that. I can see expanding on the idea as well - Thanks for posting!!
    Cheers
    Mike
    How about attaching the spring clamps on with some ball & socket joints, like this? Just add wing nuts.
    That would only work until the ball joints loosened up and and didn't have any stiction left in them. It would probably hold up for a while until the clamps just started flapping around, but in the long run you need something with an adjustable amount of friction built in.
    Poewr I-Mig 205P
    Powertig 185
    A hammer will restore the friction in a ball joint, very quickly.
    Yes, but it would be easier to just buy 3 hinges. One large like he shows in the video and two smaller ones to mount the clamps to. Drill out the 3 center pins and replace all 3 with bolts. Mount the 2 smaller hinges to the large one and mount the clamps to the smaller hinges. Now you have a fully articulating mounting system with adjustable friction in all directions. I've found the less I have to beat things with a hammer to make them work, the longer they tend to last.
    Poewr I-Mig 205P
    Powertig 185
    Yep that is a great idea.... I think I have all the parts too... guess I will be building one of these too.
    Actually this would make a good Christmas present... might have to build a couple if it works well.
    Everlast PowerTig 200DX
    Everlast Supercut 50P
    I'll pm you my address
    Poewr I-Mig 205P
    Powertig 185
    If there was a tiny version of the ball joint on this mini vise available, that would be ideal, and I'm sure many other uses for it could be found as well.
    That is a really cool idea, gonna have to make me a few of those. Some type of magnetic base to hold them up would be even cooler.
    Glenn
  1. ??Rod Dryer Idea??
    By smithkf4gyp in forum Tips & Tricks, Custom Tools, Safety, Ideas and Reviews.
    Last Post: 02-18-2018, 11:55 PM
  2. Air dyer idea
    By Gman in forum Everlast Plasma Cutters (PAC)
    Last Post: 06-14-2013, 10:54 PM
  3. Any idea what this is?
    Last Post: 12-23-2012, 03:18 AM
  4. Replies: 1
    Last Post: 03-07-2011, 04:34 PM
  5. newbie with no idea
    By mrmuddy76 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-11-2009, 03:36 AM
