Results 1 to 2 of 2
Thread: I-MIG 250P Add On Lead Hanger
    Default I-MIG 250P Add On Lead Hanger
    Having adding a 20' Profax gun and 25' ground I needed a better place to store them rather than wrapping them around the bottle.
    I used 1" square tube for the frame and 14 gauge hot rolled sheet for the reel. I used an existing bolt to attach the bottom part of the mast and drilled one 5/16" hole in the bottle bracket to secure the upper mount.
ID:	11780Click image for larger version.
ID:	11785Click image for larger version.
ID:	11783Click image for larger version.
ID:	11784Click image for larger version.
ID:	11782Click image for larger version.
ID:	11786Click image for larger version.
    I like that. Maybe instead of trying to fit the beast into a cart like I was planning, I should instead build the cart onto the welder.
  1. CK 130 Torch W/25' Superflex Lead on my PP256
    By zoama in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-17-2013, 01:21 PM
  2. power arc 140 lead up grades
    By tbucketford4 in forum Stick Welding (SMAW)
    Last Post: 11-21-2012, 03:15 PM
  3. Weld with torch lead coiled or uncoiled ?
    Last Post: 02-12-2012, 09:25 PM
  4. Lead Cable Size
    By Gerry in forum General Welder Questions
    Last Post: 12-23-2011, 02:50 AM
