T-money, maybe post up pictures if you can. That will probably get more comments to your post.
Also, it sounds as if you haven't downloaded and read the manual yet. That would help as a lot of your question(s) can be answered by reading it. We've added a lot of information.
If your filler metal is melting, then you have your torch angled too much. Stand it up. Don't try to put the filler metal under the arc. Put it in front of the arc, in the front edge of the puddle. IF you can put more than a penny under your electrode it is too much. NEVER use pure tungsten. Do not go over about 40% AC balance. Make sure you flow is set to around 7 or so. etc.
Mark
877-755-9353 x204
M-F 9am - 5pm EST
