Results 1 to 8 of 8
Thread: Dimensions of the PowerArc 140ST?
    Default Dimensions of the PowerArc 140ST?
    As hard as I tried all over this site, i cant find the dimensions of the PowerArc 140ST anywhere. Can anyone advise the length, width, height?
    Thanks.
    Millermatic 211 Mig
    Lincoln Weld-Pak 100
    Century Stick welder
    Jet band saw
    Quote Originally Posted by Joe from NY View Post
    Thanks.
    Power ARC 140 = 9.5"H x 5.125"W x 11.625"D
    There is a thread here with dimensions.
    http://www.everlastgenerators.com/fo...344-Dimensions
    I found it odd that the 140ST and the 160 STH are so different in size! Most of the other machines that are similar in features and share the same series name use the same (or very close) size case. I'd love it if my 160STH was the size of the 140ST!
    Not that much different, considering they tucked in a gas solenoid, HF module, and a little more umph. Probably more to make room on the front panel for the extra jacks and controls. 2.5" taller and just over an inch wider, with about the same length. With the gas and pedal connectors it's still pretty full.
    The 140st is jam packed in there! Not a whole lot of room left and I'm glad they made it as compact as possible.
    The size difference between the 140st and 160sth isn't much but can make the decision between the two that much more difficult for those looking for a good, reliable and ultra portable welder.
    Yup, but I think I can squeeze in one more little upgrade that I've been thinking about.
    You are such a tease! Clearly a modification within the case could void the warranty but you have my curiosity piqued now. What kind of modification, pray tell?
    I guess I should have chosen better wording. I didn't mean to say that the case sizes are all that much different, I just thought it would have been more economical for Everlast to use the larger 160STH case with the smaller (less equipped) 140ST, instead of creating another (odd sized) case just for that welder. I DID mean it when I said I wished my 160STH was the smaller dimension though! Sometimes an inch makes all the difference...or so I'm told...
  1. Just received my powerarc 140st/test run
    By ridenlow559 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 02-15-2015, 06:00 PM
  2. First beads on a PowerArc 140ST
    By MuttonHawg in forum Customer Testimonials
    Last Post: 02-25-2013, 09:28 PM
  3. PowerArc 140ST just arrived
    Last Post: 01-18-2013, 02:28 PM
  4. PowerARC 140ST demo unit
    By everlastsupport in forum Customer Testimonials
    Last Post: 04-27-2012, 10:49 PM
  5. PowerArc 140ST as a TIG WELDER ???
    By Kalikov in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 06-25-2011, 12:47 PM
