Results 1 to 11 of 11
Thread: A few Powermaster 205 questions on my new unit
    Hope you enjoy your unit. Feel free to contact us directly or post here if you have any problems or questions. To answer a few of the points you brought up:
    The tig torch has always had a switch for on and off. There is no power adjustment and never has been on the torch itself. This is strictly for operation of the panel control. If it was posted otherwise elsewhere, then it was incorrect.
    The manual is available online on the main website. Please download it. We have repeated this here on this board, but I guess it is often missed. A revised version will be up soon, but it should be adequate to get you started and include all you need to set up.
    As far as the breakdowns, tig torch assembly is pretty much universal, and even in the instruction manual for the other guys, it is not given much if any consideration. Even with incorrect assembly argon flow could not be restricted, and never has been reported in regard to incorrect torch assembly.
    All plasma torches come assembled as they are tested before they are boxed with the unit. Upon disassembly, it is easy to see how the torch goes back together.As far as problems with flow and that sort of thing, I don't remember anyone having issues on our board and haven't received any calls about it unless someone "forgot" to put in the swirl ring. But it is fairly obvious where it goes.
    As for the loose consumables, they are usually in a bag or on a vacuum packed cardboard sleeve. I am not sure why yours arrived in a loose condition.
    Post
    Here's a link to make it simple for everybody who looks at this thread.
    http://www.everlastgenerators.com/manuals.php
    Thanks! I read the current manual online before I made the purchase. Thanks for clearing up the issue with the torch being non-adjustable. I might have been confusing it with the miller I was looking at.
    I haven't had any problems yet. However, when I saw the level of support you give online on the forums here and elsewhere, it pushed me towards buying an Everlast. Thanks for being so responsive.
    Cheers!
    Sean
    Smile
    Managed to get all of the hose fittings last night to do a swap between Argon and air.
    One note, the air regulator (push lock) was frozen and unable to rotate. After spending some time with it, I managed to get the plastic cap off the top and turn it with a wrench rather than mar the finish on the cap. After that, I was able to do a pilot arc on the plasma torch to verify its operation.
    Are there normally pauses between when the arc starts, stops and when it becomes available again? It is my first experience with plasma.
    This unit sure looks good on a cart!
    With that unit, the air should flow first and there is a slight delay in arc starting, due to the blow back design of the head.
    Works like a champ. Pretty surprising just how easily it cuts 1/4 plate steel. :eek:
    Its all a learning process for me.
    With use, as the torch "limbers up" the arc starting MAY be a little quicker, as the parts "wear" in. But without me being there, I can only go by your description, and based on that, it seems to be working with the normal "pattern" of arc starting.
    I started playing with the TIG functions today. I was doing some simple puddle exercises usng some mild sheet metal (16 gauge) and was getting some massive penetration. I'm learning to tweak the pulse settings and the rehostate on the pedal to control the pulse. It is very obvious when the pulse hits. I read in a different thread that pulse isn't advised with pedal controls on this unit when using the pedal.
    Very fun machine. Very strong arc on the TIG gun. I think it will make a fun machine to learn on. I just need to learn how to dial down the setting for use with sheetmetal while using the foot pedal controls.
  1. Would like to purchase but unit not available
    By choppadude in forum Pre-sales, Sales and Shipping questions
    Last Post: 08-17-2015, 06:55 PM
  2. Control questions on the new Powermaster 205
    By junkfunnel in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 01-12-2010, 04:07 AM
  3. Powermaster 226 questions
    By ole4 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 09-23-2009, 01:11 AM
