Thanks for the reply.
I was able to get it fixed. I held it in place until it would stop working, cut the wires and spliced back together and it is working fine again.
The solder on the switch portion of the wires was fine, that led me to think it was a broken wire. One other thing, I took off the plastic sleeve cable covering, and like others have said, the torch is much easier to maneuver around. Not sure if I'm comfortable having the cables exposed, may get a after market cable cover. I've discovered I like the torch mounted switch better than using the foot pedal.
