Results 1 to 3 of 3
Thread: Everlast good Service
  1. Default Everlast good Service
    Hello all. Just wanted to relate my experience with buying and setting up my New Tig.
    I was not a Happy Camper. I bought the machine for a job to be done on location and like a dope. I received the machine loaded it in the truck and off I went. Well it appears that the shipper was not kind to the unit and I was unable to get it to work. The service tech walked me through some fixes and still no luck. Alex went above and beyond to try and fix the problem. They sent a replacement unit and once the pilot error factor (me) was corrected the unit worked great. I still have my big blue unit in the shop but the 200 DX is a permanent fixture in my field service truck. Just today it was used to put a stainless steel food processing machine back together. Just wanted to say thanks for the great service and I will buy from Everlast again.
    Attached is a Copper to Stainless I did with the 200 DX just for fun
    Glad all was worked out quick.
    I am sure others will want to know what filler did you used on the repair? Also, did you run on their 220vac or a generator?
    That was my first thought, "which filler did he use"?
    Soon to be 2013 250EX tig machine
    Lincoln Idealarc DC250 with LN7 wire feeder
    RSG250 spool gun and controller for above.
    Hypertherm Powermax85 with Machine and hand torch
    Bridgeport Milling Machine w/DRO and Powerfeed
    South Bend 9 lathe WW2 vintage
    Devilbiss 6.5hp 80gal 175psi 2 stage compressor
    HF blast Cabinet modified for foot pedal operation better gun.
    Oxy/A torches
    Delta 4x6 band saw
    Hand and power tools up the wazoo.
    The name's "Marcel" in case I forget to sign.
  1. Excellent Customer Service on my Everlast 255 EXT welder
    By CraigB1960 in forum TIG Welding (GTAW/GTAW-P)
    Last Post: 09-07-2016, 10:54 PM
  2. everlast service and tech turnaround time
    By treasony in forum Pre-sales, Sales and Shipping questions
    Last Post: 09-06-2012, 05:36 AM
  3. On customer service from Everlast #1
    By sprocket in forum Customer Testimonials
    Last Post: 05-02-2012, 01:26 AM
  4. Not a good first customer service experience !!!
    By loose1 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 03-16-2011, 04:09 AM
