Results 1 to 20 of 28
Thread: Supercut 50 p warning light
    Feb 2013
    Corner of "No" and "Where"
    Quote Originally Posted by Memnos View Post
    Very informative sticks, thanks. For a noob like me, the manual that came with the machine looks like it was written by a kid in China, then translated to English...lol. No help at all. Nowhere in there does it state anything about having an inline water dryer. How would a person know that if they've never used a plasma cutter before? I had to google to find this forum. Thanks for the manual download link. My compressor is 33 gal. Its got a max psi of 150. The output was set between 80-90 psi and on the front of the plasma cutter, the pressure was set around 60 psi. I just don't understand how something can quit working the second time I used it. I definitely dont think I was overloading it. Thanks for the help, sticks. I guess I'll be calling tech support tomorrow, cause I don't see how I could fix it. I just hope they get it back to me soon.
    33 gallon tank is 4.4 cubic feet. If it takes your compressor more than 1 minute (4.4 cfm) to fill the tank, you need a bigger compressor. In reality is should take closer to 45 seconds to fill to be in the safe zone. CFM goes down as pressure goes up. Look on your compressor for it's CFM @ PSI rating. As the Everlast tech posted earlier, if the pressure dropped too low, the torch could have shorted internally.
    Sticks
    AKA
    Quote Originally Posted by sticks View Post
    I checked the cfm....It's rated for 6.3 at 40 psi, and 8.2 at 90 psi.
    That would not be possible to have less cfm at 40 psi. Is that backwards?
    Whoops, I looked at something else..lol. It's 6.3 at 40 psi, and 4.9 at 90 psi.
    What size tank?
    What size tank?
    the tank is 33 gal.
    Feb 2013
    Well, we've come full circle, other than you are sending it back, I'd say do the test with the torch disconnected, or disabled, and see if the compressor can keep up with the cutter when the trigger is depressed. Your CFM @ 90 is awful close to the minimum requirements.
    Sticks
    AKA
  1. Supercut 50P Overcurrent light
    By cbmkr in forum Everlast Plasma Cutters (PAC)
    Last Post: 11-05-2018, 02:18 PM
  2. SuperCut 50P On New Steel 7 Ga Light Pole
    Last Post: 08-01-2012, 11:32 PM
  3. I-MIG 200 intermittent shutoff issue (green warning light)
    Last Post: 01-24-2012, 08:34 PM
  4. Supercut 50 over current light
    By outsidegangskilled in forum Everlast Plasma Cutters (PAC)
    Last Post: 09-11-2010, 01:25 AM
  5. Warning Light kicks on easily
    By chuck2302 in forum Multi-Process Units (TIG,Stick,Plasma/MIG,TIG,Stick Combo units)
    Last Post: 05-14-2010, 05:52 AM
