Results 1 to 3 of 3
Thread: Project 3 from Rambozo. Category: General Welding Repair
    Default Project 3 from Rambozo. Category: General Welding Repair
    Someone backed a sprayer into a wall and broke off a rear mount. To be fair it was probably cracked for a while before that, from the looks of things.
    This time I did have 240V, so I finally got a chance to do some TIG with the 140ST and new torch control. Cut off some of the old mount point, and added a piece of angle to cover the hole and spread out the load a little. Used ER70-S2 and about 8 CFH. Now we're cookin' with gas. Plenty of power for this, but where it was three layers I did find I had floored it for a little bit. I would say most was done around 100 amps. This little machine does as good as any other DC TIG I've used. Smooth!
ID:	9381 Click image for larger version.
ID:	9382 Click image for larger version.
ID:	9383 Click image for larger version.
    Welded everything up and shot on a little paint while it was still warm enough to get it to dry. It's a bit on the chilly side tonight. And the finished repair, ready to go out and find a new way to break something.
ID:	9385 Click image for larger version.
    Nothing like working around smelly chemicals I can tell by the rust good welding job.
    And that's after pressure washing it for at least 15-20 minutes! It was covered with this awful blue dye, stuff gets everywhere.
  1. Project 2 from Youngnstudly. Category: General Welding Repair
    By youngnstudly in forum Welding Repairs
    Last Post: 02-01-2013, 05:34 AM
  2. Project#3 from CGCINC. Category: General Welding Repair
    Last Post: 12-11-2012, 06:33 PM
  3. Project 2 from Rambozo. Category: General Welding Repair
    By Rambozo in forum Welding Repairs
    Last Post: 11-21-2012, 07:48 PM
  4. Project 1 from Rambozo. Category: General Welding repair
    Last Post: 08-01-2012, 12:45 AM
  5. Project 1 from CGCINC: Category: General welding repair
    Last Post: 07-17-2012, 02:24 AM
