Results 1 to 3 of 3
Thread: IMig 200 and 10lb spools
    Default IMig 200 and 10lb spools
    Does the imig 200 have a spool adapter for the larger spools of wire or do you just use the tension to hold it in place? I've just loaded a 10 lb spool and it's working with tension on the spool but i've seen other welders that use an insert adapter to fit the larger hole in the bigger spools. Just making sure I didn't miss something and the instructions weren't clear on loading the bigger spools.
    IMig 200
    Have you watched this video? http://www.youtube.com/watch?v=c6VE3rM7sMo
    It should explain any questions about it.
    Got it thanks! That's exactly how it did it the other day. I don't know why I forget to check the youtube channel for answers.
    IMig 200
  1. 10lb spool in 200e
    By dsthompson in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 04-15-2018, 04:31 AM
  2. Imig 205//210
    By Doc Pete in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 01-19-2017, 11:25 AM
  3. iMIG-200 speed cal
    By Rambozo in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 11-03-2016, 11:26 PM
  4. 035 welding wire 33 pound spools, $45.00 plus shipping.
    Last Post: 03-11-2013, 03:38 PM
  5. Magnets and IMig don't Mix
    By Kendall in forum MIG Welding (GMAW/GMAW-P/FCAW)
    Last Post: 01-24-2013, 06:18 AM
